please help with 2002 honda civic si knock sensor
Rep Power: 0 please help with 2002 honda civic si knock sensor
i have a honda civic si 2002 and i need to replace my knock sensor.
this is going to be my first time approaching this and i cant find a guide.
can you guys please tell me where it is? also, if you have any tips to get to it please tell .
thank you for your time
from
cona
from
cona
Re: please help with 2002 honda civic si knock sensor
2.0 DOHC: Front side of the block near the starter
Goggled:
Goggled:
Rep Power: 0 Re: please help with 2002 honda civic si knock sensor
hmm . am i going to have to take off the cylinder head to reach it ?
also, part choice . which one should i get ?
http://www.autozone.com/engine-manag...hc/540571_0_0/
or
or
You reach it from underneath.
You may need to remove a manifold support bracket to reach the sensor.
If you have codes, check if the wire got chewed by a rodent or see if someone damaged it while replacing the starter.
Needs an ELD?
Read this bulletin it has the part number to buy and a how-to:
http://engine-codes.com/uploads/honda/05-006.pdf
okay i got the part and i am finally nutting up to do attempt the fix. Anyone know the bolt size for the knock sensor?
Take 10, 12, 14, 17 wrenches with you and find out?
jessicakaybby
04-20-2015 12:11 PM
ashleymmackey
04-18-2015 09:48 PM
dooner24
04-14-2015 07:51 PM
