2005 Civic Temperature Gauge
Old 05-13-2015
Bruce.Ringler's Avatar
Bruce.Ringler is an unknown quantity at this point
Hi there
I have a 2005 Civic, 242,000 miles. Driving to work this week the temperature gauge "jumped" to H and then back down, I pulled over and checked the engine
- Engine was not hot
- No leaking antifreeze
- Overflow / reserve was full
- Radiator was 1/2 full
- Radiator fan works
- Have original Radiator
- Have original Thermostat
- Have original Water Pump
- Have original Radiator Cooling Fan
I took it to dealer, they said it was head Gasket, about $ 3000, I questioned this because I have full power / compression with motor, but could be possible.
Any ideas?
Old 05-13-2015
Prelude Owner
GolNat's Avatar
Re: 2005 Civic Temperature Gauge
Yep, head gasket. It's a common problem on 7th gens. Looks like you're went the distance at that many miles.
Old 05-13-2015
head gasket.
Old 05-14-2015
From what I am reading, it is HG
I am taking it to another shop for a 3rd opinion, can't hurt
What is the worst case, I have to fill radiator every other day until fixed?
Old 05-14-2015
Reverb2005's Avatar
Reverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of light
No, I would say that worst case if you let the engine overheat and warp the head so the new HG doesn't fit and you need a new engine.
Just be careful not to let it overheat, better yet, don't drive it until it's fixed!
Old 05-14-2015
You only need one smart person that knows how to verify and prove it's really the problem. It's not difficult at all if one knows how and is intimately familiar with this failure on this particular engine.
And you need to quit driving it.
Old 05-14-2015
mikey1's Avatar
why?
if the third opinion says its NOT the head gasket, are you going to believe them?
Old 05-18-2015
Ok, I took the Civic to a Honda Shop recommended by staff at work, $ 100.00 Compression Test and a replaced Radiator, $ 370.00 total. So, No Head Gasket replacement.
We'll see, already run 4 days in heat and holding
Old 05-18-2015
Keep your eyes open for this to happen again.
Go make sure the radiator is completely full.... and I'd mark the coolant level line in the reservoir with a Sharpie and keep an eye on it, make sure it has returned to the same level every morning before you start the car up.
It may take several hundred miles for the symptoms of low coolant level to show up if the combustion leakage rate is very slow.
Old 05-18-2015
I know, I still question a cheap repair,
Old 06-17-2015
Ok, you were right, after 5k with a new radiator, overheated, so looks like head gasket.
The shop I went to, Honda specialist in Maryland, wants $ 1100 to replace head gasket, but warned that once the engine is removed and open there could be other heat damage, in addition to 247,000 miles on the trans, so, until making a decision, I check the radiator weekly and keep it full.
B.
2005 Civic Coupe
2010 Pilot 2WD EX
2011 Accord Sedan 5 Speed Automatic EX
2013 CR-V AWD LX
Old 06-18-2015
mikey1's Avatar
why do they need to remove the engine?
Old 06-18-2015
^I totally missed that^
Wow.
If the engine has 247k miles I might want to pull pistons and stuff new rings in it due to oil consumption.
civic_gt
04-19-2015 08:15 AM
aultman1990
04-19-2015 07:14 AM
twtron
04-17-2015 12:09 AM
dano2005
04-14-2015 01:58 AM
fordfocussucks
11-06-2001 03:16 PM
Quick Reply: 2005 Civic Temperature Gauge
