reccomended power steering pump 2001 ex
just hit 200k and my power steering pump is starting to whine. any recommended units I should buy. ebays, rockauto. links would be helpful
Prelude Owner
Re: reccomended power steering pump 2001 ex
I would go here:
https://www.hondaautomotiveparts.com...artsSearch.jsp
I think you can rebuild them. Get a used one from a junk yard.
Remove it completely, it's not needed.
I'd first look see if the fluid is low.
Then see if the fluid is aerating, getting foamy in the reservoir. Maybe even belching out the top.
If it is, then the inlet tube in the pump needs the O ring replaced.
Never use ATF in these. Use only Hondas power steering fluid.
get a rebuild kit and remember turn the shaft nut clockwise to unscrew it. Autozone part # 8950 $28
mattdoc
03-14-2017 12:10 PM
RIPSAW
11-06-2015 04:36 AM
vvr210
05-31-2015 08:02 PM
