CKP Sensor Location
Rep Power: 0 CKP Sensor Location
This 2004 Civic Si is really starting to irk me because I can Google stuff till I'm blue in the face and everything I find online is for a 1.7L engine. It's like my engine barely exists.
Got a car that cranks and cranks and backfires while sounding like it's about ready to run whenever it's less than freezing outside, any other time it just starts up. A guy told me that I have an intermittent crank position sensor since I just replaced my fuel pump and verified that my PGM-FI relays are just fine.
The service manual for my car only has vague drawings in there, I honestly can't tell where this diagram is trying to draw my attention. Can anybody tell me exactly where this sensor is?
Re: CKP Sensor Location
Got fault codes that lead to that answer? Got proof? Is spark inconsistent?
Test, don't guess. Guessing can be expensive.
Is this a new problem JUST since you replaced the pump?
The 2.0 is much rarer than the 1.7 by comparison.
Does it lack sufficient fuel when this happens? Is it getting too much fuel when this happens?
Fuel pump and CKP would be pretty far down on my list of possibilities.
I might be looking on a good scanner at sensors that influence fuel injection quantity.
CKP Sensor Location
Backside of engine down low
near crank pulley in timing cover
near axle CV boot
#3 in the timing cover diagram
HTH
Rep Power: 0 Re: CKP Sensor Location
I replaced the pump because I couldn't buy just the filter alone and the filter is actually the top part of the pump. I also replaced it because the regulator is part of the pump and couldn't buy it separately. My fuel pressure was only reading about 37psi, and with the filter & regulator not being sold separately, I pretty much had to bite the $255 bullet and buy the pump.
Plugs and coils are all brand new. I also removed and manually cleaned all of my injectors a couple weeks ago. The problem with the car cranking and cranking with random backfires (and "almost starts") is about a year old, but has finally just gotten so bad that I have to do something or start looking for a job that I can walk to.
It definitely has to be an ignition issue because after an hour of fighting this endless cranking and backfiring, I can faintly smell gas when I lift the hood. I've seen other things online ( such as this site -> http://troubleshootmyvehicle.com/hon...crank-sensor-1 ) where they say an intermittent crank position sensor won't throw a code, but the car will exhibit the same problems that I'm experiencing.
Just out of curiosity, where in the world did you find that diagram? I've been looking for things like that forever and I get nothing. As I said, it's as if my engine doesn't even exist.
mohawkboom
67
08-25-2015 12:28 AM
wh3nw0rdsesc4pe
03-23-2003 09:57 AM
