O2 heater sensor problem???
Rep Power: 0 O2 heater sensor problem???
So I just replaced my vehicles entire exhaust system with brand new parts from the manifold to the muffler including both o2 sensors, now my car is getting a check engine light with codes p0135 and p0141 which are o2 sensor heating errors from what I have seen online, I am at a loss as to what it could be everything is on correctly and bolts are tight and I also disconnected the battery for an hour to reset the OBD codes then just drove it 100 miles but light is still on. Any help would be great cause I'm very confused?????? Btw I drive a 2002 Honda Civic EX... Are there any known problems like this with o2 sensors from ebay?
Re: O2 heater sensor problem???
OEM, DENSO or NTK. Check fuse 4 in the dash box too
I wouldn't put anything Bosch in a Honda. Yeah, you are lucky LOL.
that both new sensors are having a "heating malfunction"
cause it is weird
The computers can be finicky.
Yea ebay sensors are junk. Id bet that your new sensors need replaced. Only go with denso or oem.
They are a little pricey since they are wideband sensors
R3KogHyZe
21
02-03-2016 09:23 PM
juror
05-26-2015 06:35 PM
dooner24
04-14-2015 07:51 PM
