No start no crank.
Rep Power: 0 No start no crank.
Driving home the other day i stalled at a light. When I went to start it back up all i heard was a relay click. Luckily i was on a hill and able to pop the clutch and get home. however once home i now have a no crank no start issue.
my battery and alternator seem to be fine. but when i turn the key all i hear is a relay click twice.
2003 civic si 1.7l
2003 civic si 1.7l
Re: No start no crank.
start with the basics,
- test the battery voltage
- disconnect your battery, clean the battery terminals and connectors with baking soda and water mixed, clean the posts and the inside of the loops good, use a wire brush if needed
- check all main grounding points, battery to frame, strap from the frame to the engine, etc etc, make sure they are clean and tight,
- check all fuses, engine compartment and under dash, are any blown?
- check if the starter is getting power
that should get you started and keep you busy for a bit
Wild Cranker
427
01-28-2016 06:49 PM
SSMatey
04-13-2015 06:09 PM
black2k1vtec
12-06-2001 09:49 PM
