2001 civic si coupe manual transmission issues
Old 09-23-2014
01CivicSi_yyc's Avatar
01CivicSi_yyc is an unknown quantity at this point
i bought my car a couple days ago and i just started driving it. when i turn it on, the shifter will not let be change gear, it only works when the car is off. after about 20mins its fine. what could be the issue as i cant drivie the car like that.
Old 09-24-2014
Re: 2001 civic si coupe manual transmission issues
Was it like this when you had the prepurchase inspection performed?
Check the clutch fluid level.
Refill if necessary with DOT 3 brake fluid.
IF it's real empty the system may need to be bled to restore proper operation.
Then find where it leaked out at and fix it.
Old 09-24-2014
I didn't have a inspection done before I bought it. How do you check the fluid. I'm going to Mr lube today to have the filters changed and fluids topped up, as well as a quick look around
Old 09-24-2014
Have your lube place show you where.
mattdoc
03-14-2017 12:10 PM
Civicman92296
04-23-2015 09:22 PM
CapYoda
11-11-2001 05:17 PM
Lightman
11-10-2001 06:44 PM
lilbluecivic
11-07-2001 06:49 PM
Quick Reply: 2001 civic si coupe manual transmission issues
