Valves leaking air into intake manifold.
Rep Power: 242 Valves leaking air into intake manifold.
Nevermind, no text. ^_^ I did a leak-down test on TDC exhaust stroke instead of compression stroke. *facepalm*
Rep Power: 242 Re: Valves leaking air into intake manifold.
Cylinders 2/4 were leaking the most past the intake valves, while 1/3 not so much. I did a valve adjustment recently to minimum spec, but it was based on valves that had carbon deposits on them. After inspecting the clearance today, a few of the intake valves had no clearance, causing the valves to be open.
So I adjusted the clearance to maximum allowable so that I can clean the valves through hard driving, allowing them an opportunity to seat in. (.009/.011) The car is already idling properly, which it wasn't before. After about 2 weeks of hard driving, I will do another valve job and put them back to minumum spec. (007/.009)
Yeah, nothing serious. At 165k I've got really good compression:
160
160
155
155
160
160
155
155
I'm curious why you are setting them at the minimum. I would think the increased chance chance of burning a valve wouldn't be worth it.
I set Hondas valves to the loose end of the spec range because most of them tend to tighten over time and miles.
They aren't noisy when I do it, and it allows more time and miles before they need adjusted again.
Loose valves might be just noisy.
Tight valves are quiet..... BUT too tight can also lead to P0172 rich codes and burned valves.
Rep Power: 0 Re: Valves leaking air into intake manifold.
Some of the things that tight valves can cause: Low vacuum, low fuel trim numbers, high MAP voltage, low compression, misfires, stalling, burned valves, codes related to any of the above, and probably more I didn't think of right now.
Tight valves caused excessive engine vibration in trucks like mine LOL.
Any way, the reason I set them low is because the engine is significantly more responsive and tight. You can tell on these low HP engines. But you have to push the car hard before a valve job or you will not adjust properly.
Correct. Anywhere within the specified clearance adjustment range is still "in spec".
And the torque on the nuts is very important. Don't hand-tighten. 13 ft. lbs. is the spec, and it's very tight for such little nuts because they will come loose if you torque lower due to the excessive movement and the oil on the threads.
I adjust to the loose end of the specs simply because so many of the engines tend to tighten the valves as they wear. That hopefully allows more miles between needing adjustments.
(My average dealership customers don't employ the butt-dyno.)
Everyone doing this should look up the correct specs for their particular engine before the job begins.
"Too loose is too loose, and too tight can be too loose too."
crowtoo
05-11-2015 06:50 PM
