Honda Civic 2001 light issue. Part of recall?
Old 07-30-2014
HondaUserDriver's Avatar
HondaUserDriver is an unknown quantity at this point
I was going out to get dinner and all of a sudden the lights on my Honda Civic don't work anymore. Just the headlights. The turning signal, brake and parking lights all work fine. The outside headlights have sort of a faded out yellow color. I haven't tested the brights yet since I live in an apartment complex. Thank God I was able to quickly turn around and pull back into the apartments. Could have been an accident. Just glad I'm safe and realized the problem. I turned onto a side street and checked the hazards, brake lights and so on, and they all worked fine. Even my lights inside the car that told me the headlights were working were on!!! I'm taking it to the dealer tomorrow. If this is part of the recall issue that happened several years ago, the dealers fix it for free right?
Old 07-30-2014
Re: Honda Civic 2001 light issue. Part of recall?
There's a recall for low beam headlights inop on some of the cars. Enter your VIN to see if yours needs done:
http://m.owners.honda.com/Recall
Old 07-30-2014
Will do. Decided to risk neighbors' wrath and test high beams. They were perfectly.
Old 07-30-2014
Edit: I'll look in the morning and let you know what I find.
Old 07-30-2014
Never mind. Looks like I'll have to check in the morning. Found the answer online.
Old 07-30-2014
Originally Posted by HondaUserDriver
Two letters and a number right? Example AS1.
VIN is 17 digits (characters) long. Bottom of the windshield, drivers side.
Also on a sticker in the door jamb, and almost every original major body panel.
Old 08-08-2014
HONDA-AL's Avatar
HONDA-AL is an unknown quantity at this point
I am having a similar issue, however my prob is with my high beams. The low beams work fine but for some unknown reason my hi-beams are inoperable. The high beam indicator does not even come on when I turn them on. I have checked all fuses, relays and bulbs that I could find without success. HELP!!!
Old 08-08-2014
The recall does not cover that particular failure.
However, if the recall does in fact apply to your car (dealer must check the VIN), you still should have it performed.
jessicakaybby
04-20-2015 12:11 PM
CascadiaBlue
04-18-2015 09:13 AM
bahena08
04-11-2015 05:09 PM
aZnVoYCe
12-07-2001 12:41 AM
liljoe
11-04-2001 01:27 PM
Quick Reply: Honda Civic 2001 light issue. Part of recall?
