Transmission Help!!!! Control Shift Solenoid Problem!!!
Rep Power: 0 Transmission Help!!!! Control Shift Solenoid Problem!!!
OK, here's my problem. I have a 2001 Honda Civic LX that gave me code P0758. I know thats the Control Shift Solenoid Valve and I changed the part. Cleared the computer, cleared the codes. Now the computer is giving me code P0753, which is the "A" Solenoid. The part is brand new, so I do not understand how it could be the Control Shift Solenoid, unless PartsGeek.com sent me a bad part. What else could cause this problem? The transmission is brand new as I had a new one installed in the car about two years ago. Could it be a computer problem? Any help will be greatly appreciated!
Re: Transmission Help!!!! Control Shift Solenoid Problem!!!
P0758 was "a problem in shift solenoid valve B circuit".
P0753 is "a problem in shift solenoid valve A circuit".
Both are a strictly electrical problem, not a mechanical fault.
http://troubleshootmyvehicle.com/honda/1.7L/shift-solenoid-A-and-B-tests-1
HTH
HTH
The following users liked this post:
Jason12 (02-07-2024)
Marcus2thextrem
05-10-2015 03:08 PM
Russps
11-08-2001 02:00 AM
