2003 honda civic Transmission not shifting.
Rep Power: 0 2003 honda civic Transmission not shifting.
My 2003 Honda Civic with manual transmission stopped shifting when I push on the clutch pedal. I now have to force it when changing gears. This started almost instantly. It was shifting very smooth and easy before that. The clutch still disengages the transmission when I stop. Can someone give me an Idea of what might be wrong and what to look for first. I would appreciate any advise.
Re: 2003 honda civic Transmission not shifting.
Check clutch fluid
Check shifter linkages/cables
Does it shift with the engine turned off and the front wheels raised off the ground?
Rep Power: 0 Re: 2003 honda civic Transmission not shifting.
I did add some clutch fuid which was a little low. That seems to have resolved the issue. I will watch for leaks. Thank you
alexkharden
04-23-2015 07:13 PM
jessicakaybby
04-20-2015 12:11 PM
dooner24
04-14-2015 07:51 PM
