2001 civic dx, D17A2
Rep Power: 0 2001 civic dx, D17A2
looking for advice on how to diagnose/fix my car. The engine will roll over, but wont start, shakes like a bitch when its trying to start. check engine light is off.
Re: 2001 civic dx, D17A2
You can take a volt meter and make sure it's putting out around 12v.
Do your lights dims when you try to start the car?
Start with that.
Then you can pull out your fuel line and crank the car a bit to see if your getting fuel. Then you can test for spark. Pulling a spark plug is the easist way.
Start with that.
Rep Power: 0 Re: 2001 civic dx, D17A2
Start with that.
Start with that.
*watches temp gauge like a hawkboss* :D
1 Post
Rep Power: 130 Re: 2001 civic dx, D17A2
YES do not check for spark holding it in your hand. That's 30K volts at least -- and if you're really unlucky, it'll find a tenth of an amp on your body and ground through it.
Best thing is to buy a tool to do this -- looks like two clips on a cable but one fits on the plug, the other on a known good ground (best on the engine, not the neg terminal on the battery). Because the D17 has coil-on-plug theres 1) no way to hold the plug on the coil and 2) there's little to no slack with the primary wires to touch the plug to a ground.
When was the fuel filter last changed?
Check back after the spark test...
Yes that will work if you know how to use it
If not, here is a great article:
http://easyautodiagnostics.com/HEI-S...k_tester_1.php
Hi I posted yesterday about my civic not starting, the starter cranks the fuel is pumping, ive checked my coilover boots and replaced my spark plugs but the car still will not run. Any advice at all would help thank you
Received 1,440 Likes
Rep Power: 338 Re: 2001 civic dx, D17A2
I merged your new thread with this older one.
In the meantime, I moved it from the 8th gen, yours is NOT a 8th gen, it's a 7th gen, so STOP posting in there.
Rep Power: 0 Thread
mattdoc
03-14-2017 12:10 PM
CapYoda
11-11-2001 05:17 PM
Lightman
11-10-2001 06:44 PM
