2002 Civic Ex p1361, p1298, p0336, p0135
Rep Power: 0 2002 Civic Ex p1361, p1298, p0336, p0135
Alright, after about 20-30 miles on a warm day my car bogs, starts to lose power and then slows down to a stall. I can wait about 30 minutes and it will start up and I can drive 10 or so more miles before it does it again. I've replaced the upstream o2 sensor, tdc sensor along with the timing belt, and complete new exhaust(not sure if relevant) and nothing has seemed to work.
Before the car overheats, or whatever it does, the CEL is off. Today, when it happened to me again I took it to O'Reilly's and got the CEL diagnosed and this time I got 4 readings back:
P1361 - TDC (already replaced don't understand it)
P1298 - Electrical Load Detector Circuit High Input
P0336 - CKP sensor 'A' Circuit Range/Performance
P0135 - Cracked Exhaust Manifold(Just got a new exchaust, so I don't get it)
If there's any experienced mechanic willing to point me in the right direction would be greatly appreciated.
Re: 2002 Civic Ex p1361, p1298, p0336, p0135
See which codes return after driving.
Both of these codes are for "intermittent interruption".
Sensors, wiring, terminal tension, terminal corrosion, etc.
Is the sensor OEM?
HTH
CarStuff
12-06-2020 12:52 PM
CapYoda
11-11-2001 05:17 PM
