need help with catalyic convertor selection
Rep Power: 0 need help with catalyic convertor selection
Need a new cat convertor. what would be the difference(if any) between these ones
http://www.canadiantire.ca/en/pdp/wa...l#.Uojk43dYHMg
and this one
www.hottexhaust.com/Magnaflow_93228
they both have 2 year warranty. which probalby means they are going to both die in about 2-3 years.
going for original OEM isnt option for me since i know they cost 1400$
Please help me select
P.s my car is 2004 civic ex
and this one
Re: need help with catalyic convertor selection
California CARB approved would be my 2nd choice after factory.
No choices after that. I can't afford to install cheap parts in customer cars.
EDIT: wait, you're talking Canadian? IDK.
Rep Power: 0 Re: need help with catalyic convertor selection
I'm thinking as though I'm at work again.
When I have to replace a cat, I need it to last as long as possible. I can't ever believe someone that says they only need it to last a year or two, because most people lie their asses off if it will get them a cheaper price. (Therefore the cheapo cat choice is not offered.)
Factory cat is always first choice.
California CARB approved is second choice.
If someone wants to go cheaper, they can go somewhere else and be upset at THAT shop when it fails.
These are based on expected longevity, and warranty.
Check into those aspects.
Is that Magnaflow choice approved by CARB for sale and use in California?
(NO.)
See if they DO have a CARB approved choice if you need for it to last a long time.
If you only need a couple more years out of the car, then go cheapo if you like.
JMO, HTH
(NO.)
JMO, HTH
I believe California regulations demands a 5 year/50,000 mile warranty on approved cats. (I'm not sure how that works if they send one to Canada though.)
Most aftermarket units only get a 1 year warranty.
(NO.)
JMO, HTH
(NO.)
JMO, HTH
If you only need 3 years, maybe wait until your test date comes near then install the Magnaflow direct-fit looking unit and see how long it lasts?
I didn't see a Calif approved cat that looks right on the Magnaflow site, only saw the manifold type..... Wow.
Funny..... Figured I'd look at factory stuff a sec..
Looking in http://torontohondaparts.com/ they don't list an EX. Hmmm.
I assume your cat is under the car, not built into of the manifold? They want $1200 for theirs.
Any way you can sneak parts across the border? Majestic shows almost half that price for theirs $687 USD (no clue what the exchange rate is though)
Thought about a used OE cat from a recycle yard/used car/Craigslist part-out?
7th Gen Civic DIY Enthusiast!
Rep Power: 161 Re: need help with catalyic convertor selection
yeah2004 canadian SI is an equavalent of EX in US. and i thought about grabbing one from junkyard. not sure if ill be able to find exactly one for my car though
and yes my cat is under the car not attached to manifold
and im willing to wait until my emission test is due, but just worried about if my fuel economy is going to hurt coz of bad cat.
The engine and computer is a life-support system for the catalytic converter, first and foremost. (Propelling the car down the road is entirely secondary!)
The PCM can constantly manipulate fuel control as it tries to obtain a desired reaction/reading from the rear O2 sensor.
If the cat is bad/missing or has an O2 fooler of any type on the rear sensor, the PCM can go nuts with fuel delivery, unchecked. THAT'S when mileage gets affected.
If the guy is **** about checking mileage he'd probably notice a bit of difference. Probably not much, but I really can't say that for certain.
HTH
1 Post
Rep Power: 117 Re: need help with catalyic convertor selection
Rep Power: 125 Re: need help with catalyic convertor selection
But how would the car's computer react to a non OEM cat? I don't want to replace any part and have terrible gas mileage or a constant lit CEL.
Dude DONT! I went through this same situation, thinking I could utilize the replacement for a "high-Flow" cat. They don't exist man, just go with what should be on there, don't listen to all the marketing BS. SAVE YOUR MONEY BUY THE RIGHT PART!!
Who decided to drag this old thread out? It's dead.
Seems like carid used to be a sponsor here on this site.
EDIT:carid is a Premium Sponsor
Then you get to find out why they are cheap.
(I've seen an ad that showed an empty cat shell and called it "high flow" LOL. No cat at all.)
The computer hates them, half of them can't make it past the 1 year warranty. This is important if you have to pass an emissions test.
I only offer the factory cat or California CARB certified cat to a customer. (I only have to deal with stock cars too.)
I won't even offer a cheap cat to a customer because they fail so frequently. If a customer wants a cheap cat they can go elsewhere and be pissed at that shop when it fails too soon, and frequently.
A correctly sized cat will flow far more than the engine is capable of producing. Stock OE.
If I had to replace my catalyic converter I would opt for a "high flow catalytic converter" they are less restrictive and usually less expensive.
jdh022764
18
11-03-2015 06:44 AM
Civic720
09-10-2015 10:06 AM
carid
08-08-2015 05:05 PM
cgavin1
07-07-2015 07:10 AM
