Heater wont blow hot air
Rep Power: 0 Heater wont blow hot air
hey i have a 02 civic and my heating system seems to have a mind of its own everytime i put hot air on it blows cold air and after a while it`ll go to hot air and so on. I checked the engine coolant is it the thermostate or something more serous any help will be appreciated thanks!
7th Gen Civic DIY Enthusiast!
Rep Power: 161 Re: Heater wont blow hot air
Have you checked your coolant level in the reserve tank/overflow? Have you burped you coolant system lately making sure all the airs out of it? Is the radiator full to the top? Have you overheated?
It sounds like you have air in your cooling system. If your coolant levels are normal then I would bleed the system and see of the symptoms return.
If the symptoms return you may be experiencing a head gasket failure. There are about 5 trillion threads on it by now. Do a search.
sk8ermommie
06-09-2015 10:41 PM
mrohitredd
05-30-2015 06:51 PM
g4384063
05-30-2015 11:21 AM
jc33312
05-12-2015 03:17 PM
