2002 Honda Civic EX Timing Belt Change
Rep Power: 0 2002 Honda Civic EX Timing Belt Change
I just bought my mother-in-laws 2002 Honda Civic. It only has 78,000 miles on it. I debated on where or not to do a timing belt replacement b/c of low miles. Since it is past the 7 year mark and well on its way past 10 years. I decided to do a DIY replacement.
My progress thus far is I have gotten the bolt off. I can see the timing belt and it looks like it is in great condition. I suppose it should still be replaced???
I am having problems finding the pointer on oil pump mark. I can't seem to be able to locate it??
Also I bought a timing belt from NAPA . The man at the store seemed unsure if this was the exact one needed. It is Mitsuboshi CD312. I have no idea is OE or not. Any suggestions??
7th Gen Civic DIY Enthusiast!
Rep Power: 161 Re: 2002 Honda Civic EX Timing Belt Change
If I were you I would have gotten all this material together before starting the job.
You may need to clean the pump off to find it, but the arrow for TDC is part of the oil pump casting. There is just a line notch on the crank piece that the belt rides on.
Do a search for 7th gen timing belt change on youtube. One guy has an OK video on how to change the timing belt and what to look for. I'd never follow it, but then again I knew what I was doing when I did my timing belt and associated components.
Watch out for that recessed timing belt cover bolt. I broke my lower timing belt cover because I didn't get that bolt out. So did the guy in the video, but he never realized it.
Good luck!
Rep Power: 0 Re: 2002 Honda Civic EX Timing Belt Change
Get a HONDA belt. There are a few websites where you can get original OEM stuff at reasonable prices.
Received 1,148 Likes
Rep Power: 485 Re: 2002 Honda Civic EX Timing Belt Change
hondapartscheap.com and hondaautomotiveparts.com is where I order OEM stuff from
Whachya lookin at?
Rep Power: 289 Re: 2002 Honda Civic EX Timing Belt Change
Napa is fine. Most belts you get from Honda dealerships tend to be aftermarket anyway. Mitsubishi is a good brand.
CarStuff
12-06-2020 12:52 PM
mattdoc
03-14-2017 12:10 PM
jessicakaybby
04-20-2015 12:11 PM
