cover gasket? (PICS)
Rep Power: 0 cover gasket? (PICS)
Got a small, drop by drop of fresh oil coming out of the bottom of this black cap thingy. Not sure what its for.
This is a 01 civic lx
Please tell me this is just a simple fix >.>
Re: cover gasket? (PICS)
That is your cam seal,
here is a post i found that might be helpful to you...
https://www.civicforums.com/forums/1...-question.html
http://www.youtube.com/watch?v=F1yzbcBdj1I&sns=em
Low and slow!
1 Post
Rep Power: 190 Re: cover gasket? (PICS)
That is your cam seal, it is notorious for leaks. Just take off the valve cover and take that little plug off and put some liquid gasket around it and put it back on and your set no more leak.
the link that i shared said that you do not have to take the valve cover off, just use a small flat head screw driver and pry it off. order a new seal from dealership and get some hondabond. i also posted a youtube vid, he doesn't actually do it but walks through it pretty well. should help you out
Low and slow!
1 Post
I take the valve cover off cause its easy to jack the plug up popping it out with a screw driver. It takes like 5 mins to take the valve cover off and get to the plug. He doesn't need to buy another one. All he needs is some liquid gasket and put it slightly around the plug.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
03-28-2022 07:35 AM
JohnnyBxo
16
05-09-2015 05:53 PM
