2005 Honda EX---Coolant in overflow tank and car overheating - Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 11-06-2011   #1
needhondahelp is an unknown quantity at this point
Hi Everyone!
I have a 2005 Ex with problems that started about a year ago and are continually getting worse. Last year the car started over heating when we checked the coolant it was almost empty. So we refilled it let the car cool off then drove home. When we pulled in the drive collant started blowing out everywhere, so we replaced the thermostat and the car seemed to work fine for a while. Now when it is at idle for a few mins(only sometimes) it will overheat. We have replaced the fan switches, radiator cap, and several thermostats. It seems as if once the car gets hot/runs all of the coolant gets sucked into the overflow tank. Now the overflow tank is way over the max fill line. Also even after the car is cooled off the radiator cap is still pressurized.
When I have taken it to the shop they think i am crazy because it only overheats sometimes. Several people have told me it sounds like a blown head gasket.
Any help would be greatly appreciated! Thanks!
needhondahelp is offline   Reply With Quote
Old 11-07-2011   #2
Trance Addict
MelJ's Avatar
Re: 2005 Honda EX---Coolant in overflow tank and car overheating
http://www.civicforums.com/forums/36...reference.html
Might wanna head over to this. Seems like it may be a HG. You've thrown tons of money at symptoms but not the cause.
MelJ is offline   Reply With Quote
Old 11-07-2011   #3
anibis will become famous soon enoughanibis will become famous soon enough
With these cars it's usually the thermostat or head gasket. Since you've replaced the thermostat multiple times I'd have to agree with the head gasket being the problem, very common on 7th gen's.
anibis is offline   Reply With Quote
Old 11-07-2011   #4
Images: 178
unless he used aftermarket thermostat and its only opening 1/2 of what it should be.
gearbox is offline   Reply With Quote
Old 11-07-2011   #5
Ya he says he tried "several thermostats" so I assume at least one of those was OEM...
Old 11-08-2011   #6
The first one was after market and the second came from Honda. Thanks for all the posts. I got sick of wasting money so I dropped it off at the shop yesterday but haven't heard from them yet. I will update when I hear something.
Thread Thread Starter Honda Civic Forum Replies Last Post
Wierd Electrical Issues - 2005 Civic civic_gt Mechanical Problems/Vehicle Issues and Fix-it Forum 4 04-19-2015 09:15 AM
2005 Civic No Power, No Dome light, will not crank twtron Electrical, Wiring, and In Car Entertainment 6 04-17-2015 01:09 AM
Starter has failed 3 times in less than a year gabrown2 Mechanical Problems/Vehicle Issues and Fix-it Forum 2 04-11-2015 09:22 PM
Does anybody know a cheap, good body shop? aZnVoYCe West 4 12-07-2001 01:41 AM
Need help! Magnaflow or Mozart (Konig) muffler? aZnVoYCe Basic Engine Performance 3 11-04-2001 11:18 AM
Tags
05, 1993, 2005, amount, antifreeze, cap, civic, coolant, cylinder, honda, overflow, overheating, problem, si
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All Content Copyright 2007 CivicForums.com
