Hood latch broken at mounting bracket.
Old 10-08-2011
F15E154's Avatar
F15E154 is an unknown quantity at this point
Good morning. Just purchased a 2002 4 Door LX for my son, after bringing it home I noticed that the hood latch mechanism (under hood) is broken at the mounting bracket. It appears the previous owner liked to slam the hood vs. actually seeing what was broken. The mechanism itself is fine, but there are 3 screws (8mm?) holding it to the bracket and it is physically cracked which allows the lock to move thus preventing the hood from completely closing. Anyone had this problem? It looks like I can just get a welder to support it for me.....thoughts?
Thanks, Rick
Old 10-08-2011
Re: Hood latch broken at mounting bracket.
i would just get a new latch. you may need to move it around by loosening the screws if you ever want to adjust the hood height (in the cold vs hot, sometimes stuff shrinks and you can get the hood rattling).
Old 10-09-2011
F15E154's Avatar
Latch isn't broken - the mounting plate behind it is.
Old 10-09-2011
oh okay yeah in that case welding should work.
Old 10-11-2011
7th Gen Civic DIY Enthusiast!
Matt_75's Avatar
Are you saying that the part that the latch mechanism mounts to is broken or that the latch mechanism bracket that mounts to the car is broken?
Sorry if I'm misunderstanding you, but I'm just trying to clarify to help you better.
Old 06-29-2016
conceptvbs's Avatar
conceptvbs is an unknown quantity at this point
The latch mechanism bracket attached to the radiator support frame.
Sorry to revive an old thread but here is a solution to this problem if anyone was searching.
Old 07-16-2018
jcsk2008's Avatar
jcsk2008 is an unknown quantity at this point
2015 honda fit front end minor collision, replaced all parts, tried loosening hood bracket screws to align but latch still not locking.
everything ( plastic) is about 1 inch off but made it fit together. Question: can a mechanic cut and weld the hook on hood to make fit into latch to lock?
mr_clean
02-17-2011 08:26 PM
jim easy
10-03-2010 11:16 AM
EuroEMII
08-10-2006 06:41 PM
civic02ex
07-17-2004 01:30 PM
v8eaterokv6
02-17-2004 12:27 PM
Quick Reply: Hood latch broken at mounting bracket.
