Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen > Mechanical Problems/Vehicle Issues and Fix-it Forum
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 08-13-2011   #1 (permalink)
Points: 23, Level: 1
Points: 23, Level: 1 Points: 23, Level: 1 Points: 23, Level: 1
Level up: 45%, 27 Points needed
Level up: 45% Level up: 45% Level up: 45%
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
bamp is an unknown quantity at this point
03 Civic Si charging system issues
Could you some help with this issue. Driving the other day and the charging light came on checked the voltage and it was charging at approx 12 volts checked the fuse and it was blown. Replaced fuse the light went off and then blew after driving about 10 miles. Check engine light is on for a faulty 02 sensor and p1298 which is the ELD. Replaced the ELD but there is obviously a short somewhere which is making the number 10 fuse for the alternator go. Once the fuse blew my speedo stopped working and the EPS light came on as well. Ran the codes and the VSS sensor, the cam sensor, and the ELD is still stored in the ECU. Anyone have this issue before and have any insight as to where to start to fix the problem?
bamp is offline   Reply With Quote
Old 08-14-2011   #2 (permalink)
lazlong's Avatar
Points: 16,612, Level: 82
Points: 16,612, Level: 82 Points: 16,612, Level: 82 Points: 16,612, Level: 82
Level up: 53%, 238 Points needed
Level up: 53% Level up: 53% Level up: 53%
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of lazlong has much to be proud of
Re: 03 Civic Si charging system issues
Start by checking for bad grounds, first to usually go is the one going from the block to the radiator support. Then check for bad wires or connections, I would start at the ECM/PCM and under dash fuse box. If you can't find anything I would diagnose for a bad multiplex control unit (MCU) which is integrated into the under dash fuse box.
lazlong is offline   Reply With Quote
Old 08-14-2011
CivicForums
Honda Civic
Paid Advertisement
Tags
01 , 03 , 04 , charging , check , civic , common , honda , intermittent , light , multiplex , problems , si , system , troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Who's had a bad transmission? *UPDATED*
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Your answer may be here! TSB / Honda Complaint Address / Etc...
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
ODB II Codes
DRL Problem
DIY: replacing power window motor assembly on my civic coupe
I Got 2 ECU Codes P1298 and P1519
check engine light
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
