condenser fan
Rep Power: 0 condenser fan
Any tips on replacing a condenser fan in a 2001 civic. Doesn't seem to be enough room to pull fan out the top. Does the bumper cover need to come off? Does fan come out from bottom?
Thanks,
Travis
Thanks,
Travis
Rep Power: 210 Re: condenser fan
1. Remove bumper and grille
2. Disconnect fan connector
3. Remove upper radiator brackets (2)
4. Pull radiator forward and you should be able to sneak the fan out of there. If you can't just disconnect the upper radiator hose for more room.
7th Gen Civic DIY Enthusiast!
Rep Power: 161 Re: condenser fan
I know this threads over a year old, but it's what my issue is about.
Is the above true for the condenser fan or the radiator fan? The condenser fan looks like a PITA to remove compared to the radiator fan. I'm about to replace my rad and I'm concerned about getting the condenser fan out of the way or moved enough to get the ATF pipe past it if I can't remove the fan.
I tried looking for some clear instructions specifically for the condenser fan in the service manual on removal, but did not find any.
Any info is appreciated.
Re: condenser fan
Thanks.
Rusty
Re: condenser fan
Rusty
h4ldol
04-24-2017 08:16 PM
solarpunk70
04-12-2016 11:43 AM
Scout1
10-05-2015 01:33 PM
