Interior Post about Interior parts, seats, consoles, etc
dome light not working when door open.
Old 05-14-2011
03 lx coupe
$N00Z3's Avatar
$N00Z3 is an unknown quantity at this point
hey guys my dome light doesnt work when the door is open and the switch is in the middle position. when i turn it on the dome light works. when my doors are open i get the chime if i leave my keys in or have my lights on so the sensor seems to work but something is preventing the dome light to turn on when the door opens or i unlock my car with the remote, as it use to. any ideas what to check? ive checked the fuse and its fine
could it be a burnt relay?
Old 05-14-2011
CraigW's Avatar
Re: dome light not working when door open.
It is taken care of by the micu/multiplex located in the under dash fuse box.
Passenger side not working also ??
Old 05-15-2011
03 lx coupe
$N00Z3's Avatar
ya same thing with the passenger side. i didnt think that this would have made a problem but i ran a wire from my dome light through my side panal down to the driver and passenger kick space to put in leds to illuminate the foot space could it be too much power being pulled? it worked with all lights for a few weeks then im not too sure what happened it all just died. and i replaced my fuse and now just the on position on my switch works.
Old 05-15-2011
CraigW's Avatar
So you had an open fuse ?? What # in which box ?? Did the fuse open again ?? The correct size fuse, I hope.
I like to keep the dome leads together as a pair. (+12 volts & ground via multiplex unit)
Old 05-15-2011
03 lx coupe
$N00Z3's Avatar
its a 7.5 fuse in the engine bay. i think its called small lights was blown.
Old 05-16-2011
03 lx coupe
$N00Z3's Avatar
where can i get a new micu/multiplex? about how much does it cost and how difficult is it to install? even after i changed the fuse the light only works in the on position doesnt come on with the door open.
Old 05-16-2011
03 lx coupe
$N00Z3's Avatar
double post
Old 05-17-2011
CraigW's Avatar
The under dash box drops down after removing single bolt. Many, many electrical connectors used that have release clips holding them in place. Might want to take pictures, draw a diagram or similar before taking them loose.
And of course make the battery is disconnected.
Old 05-18-2011
03 lx coupe
$N00Z3's Avatar
Thanks, going to call Honda and see how much it is to get the part.
ORskier
05-03-2015 12:54 PM
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
twtron
04-17-2015 12:09 AM
meels808
11-05-2001 09:15 AM
TropiKalCiviC
09-25-2001 07:02 PM
Quick Reply: dome light not working when door open.
