Burn Smell and Emmission LIght
Rep Power: 0 Burn Smell and Emmission LIght
I have a 2005 Honda Civic 4 door with about 71K miles. Do all routine maintenance and reco at mileage intervals.
Past year on and off: burn smell when turn on a/c, heat and/or defroster.
Have brought up 7-8 times and told they can't find a problem (Honda dealer); that I need to come in when happening for them to diagnose; put "air freshener" in.
About one month ago, on/off the emmission light is on; called and was told could be gas cap; it stopped but again has been on steady the past five days.
Are these two connected? If not, thoughts on the causes? Any help would be much appreciated. Have a good one.
Trance Addict
Re: Burn Smell and Emmission LIght
Would you happen to have the code(s) handy? It could be as simple as a loose gas cap, to something more serious like a failing/failed catalytic converter. If it's the former, I'd just check it and reset the CEL and see what happens. If you can, please provide the code as it will help us give you a better idea of how to help fix the issue. It seems the dealer is giving you the runaround, which doesn't really surprise me. Lol.
CarStuff
12-06-2020 12:52 PM
jc33312
05-12-2015 03:17 PM
Civicchicky87
Idle Issues
04-22-2015 07:16 PM
