01 Honda Civic EX with 137k Miles stutters at acceleration from 40->50->55 - Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 03-06-2011   #1
Doll01 is an unknown quantity at this point
-Check engine light's on
-Jerks sometimes-pulling feeling
-Car starting to shake a bit when at a stop
-Stutters when accelerating on the freeway trying to pass 55, after reach 65 it stops
-Humming noise
-starting to hear a click click when let go of gas or break petals
-when gets wet, the car makes a screeching noise
-car picks up slower than before after a stop, feels like engine is weak
-starting to notice that at first gear, car picking up, the rpm thing goes up way fast into 2nd
My brother thought it was the sparks plugs, changed that and car ran good for a week and now check engine light is back on again with the same symptoms.
Please tell me what's wrong with it and tell me it's nothing too bad. -_-
Doll01 is offline   Reply With Quote
Old 03-06-2011   #2
lazlong's Avatar
Re: 01 Honda Civic EX with 137k Miles stutters at acceleration from 40->50->55
Screeching is one of the belts slipping. Even when wet it shouldn't screech tho. This could be caused by a bad belt, bad belt tension; alternator, power steering, or compressor/clutch seizing up.
Some of the other symptoms make it sound like it's running lean which could be caused by a bad cat or fuel pump/filter problems so, you really need to scan for codes. It's free at autozone. Post up the EXACT code and we can go from there.
lazlong is offline   Reply With Quote
Thread Thread Starter Honda Civic Forum Replies Last Post
00 honda civic lx overheating jessicakaybby Mechanical Problems/Vehicle Issues and Fix-it Forum 5 04-20-2015 01:11 PM
Wierd Electrical Issues - 2005 Civic civic_gt Mechanical Problems/Vehicle Issues and Fix-it Forum 4 04-19-2015 09:15 AM
Hello from Oregon! CascadiaBlue Introduce Yourself! 11 04-18-2015 10:13 AM
2003 Hybrid with hesitation/ stuttering at low rpms/speed dooner24 Mechanical Problems/Vehicle Issues and Fix-it Forum 1 04-14-2015 08:51 PM
Timing belt question dano2005 7th Generation Civic 4 04-14-2015 02:58 AM
Tags
137k, 7th, 97, accelerating, acceleration, civic, codes, engine, gen, honda, light, miles, stutter, stuttering, stutters
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright 2007 CivicForums.com
