clutch
Rep Power: 0 clutch
i have a 2003 honda civic ex coupe, 1.7l sohc motor
ok. i am having the problem of my clutch pedal is very stiff or hard to press, and when the car is running i can not get the car to go into gear at all.
i can start the car in a gear though and it will automatically start taking off from a dead stop.
i can move thru the gears fine when the car is not running as well.
Received 1,146 Likes
Rep Power: 485 Re: clutch
Try a tranny fluid drain and fill. See if that helps at all.
Could be a number of problems otherwise: synchros, bearings, etc..
Rep Power: 0 Re: clutch
any ideas on what would make it sound like its just spinning, like if i am driving and i am slowing down and push the clutch in, almost like its not engaging kinda thing, it just sounds like the clutch or a bearing is just spinning around inside
so i found out what it was. it had a daikon clutch in it and it was a dual spring, well one set of springs was completely gone and then one was starting to break. put a act street performance clutch and Pres plate in it, new throw out bearing, and its good ot go now.
but what would cause the springs to just break like that?
Received 1,440 Likes
Rep Power: 338 Re: clutch
RU the first owner? bad clutch habits could do that
sesi
10-01-2015 02:03 PM
ThatGuy913
09-28-2015 05:35 PM
powman02
09-15-2015 07:38 PM
Klame9420
09-07-2015 10:03 PM
