HElP drive ok for few miles rpm drops cars turn off wait a few min and starts normaly
Rep Power: 0 HElP drive ok for few miles rpm drops cars turn off wait a few min and starts normaly
can someone help me! I was driving the other day when my civic lx 01 rpm just drop and i couldt accelerate past 20 mph when i pressed the brake my car would just turn off took it to a repair shop said the catalyct was clog took it out installed a header on it drives ok for a few miles but does the same tock it to scan and it says the o2 is bad and the tdc sensor could this be it plz help me. it drive ecellent for a few miles no traffic or for half an hour but after that the rpm just drop its stop i wait 10 mi and the car just drive fine till it does the same any ideas plzzzzz
THX IN ADVANCE
jack
THX IN ADVANCE
jack
Rep Power: 787 Re: HElP drive ok for few miles rpm drops cars turn off wait a few min and starts nor
clogged IAC valve (idle air valve on the throttle body with coolant lines going to it) will cause stalling too
i just had that exact problem like two days ago i changed the (cam position sen) part#su5583 and it was $51.99 and my car has been fine since if but to put it in you will need to remove you valve cover just enough to get your timming belt cover off and youll see the sensor in side there. its like the only thing with wires and rubber boot going through your timming belt cover. if you need pics just ask and ill show you were everything is
Blaster30
04-22-2015 12:21 PM
dooner24
04-14-2015 07:51 PM
SSMatey
04-13-2015 06:09 PM
