DIY timing belt or have mechanic do it??
Rep Power: 0 DIY timing belt or have mechanic do it??
Hey guys, my cars a little over 100k miles, and ive got some squealing come from one of my belts im going to see which one but regardless this made me notice my timing belt is up for a change, i like to learn new things but am by no means a mechanic, i have a fairly good stack of tools, jack, stands etc, and am wondering whether you recommend me follow one of the DIY's on the site or suck up about 400 bucks and bring it to a mechanic? thanks.
TRUST me! I'm Idiot Proof!
Rep Power: 165 Re: DIY timing belt or have mechanic do it??
Do it man!! If your going to have some jack@ss monkeying around with your car, may as well be you, right?!
Just follow this excellent write up, and dont cut corners.
I did mine over the weekend, last week.
Good luck!!
Good luck!!
Whachya lookin at?
Rep Power: 288 Re: DIY timing belt or have mechanic do it??
Dooooo it... Make sure you buy the crank pulley holder tool or you will find yourself stuck! but its doable. It's actually an easy job if you take your time.
Live for the Twisties
Rep Power: 260 Re: DIY timing belt or have mechanic do it??
I've been thinking about whether to DIY my timing belt or take it to the dealership for awhile - I decided to take it to the dealership, because it takes a good 2 days to complete if you've never done it before.
I'd rather work an extra two days over the weekend to cover the cost and let the mechanic install my timing belt.
Rep Power: 0 Re: DIY timing belt or have mechanic do it??
I'm the guy who wrote the DIY listed above. It will take 2 full days to do the job. I strongly recommend that you have a helper to remove and replace the crankshaft bolt. Removing the bolt is the most difficult part of the job and it's best to have a helper. The cost for this job in northern California is closer to $700. Just remember that the civic has an "interference fit engine" so you will damage the valves if you get it wrong.
Rep Power: 263 Re: DIY timing belt or have mechanic do it??
my recommendation for OP is if you have the time and help do it yourself.
EM2ti
Rep Power: 269 Re: DIY timing belt or have mechanic do it??
I did mine about 6 or 8 months ago. I consider myself a fairly decent mechanic. I've performed all of my own mods. From suspension, exhaust, engine work, valve jobs, port/polish, welding, even mounting my own tires, etc, etc. I've got a lift at my disposal, an air compressor and all the tools you can shake a stick at(I'm not rich, I have a Marine Corp DIY Garage nearby). I even have 2 or 3 ASE Certified mechanics to ask questions or assist if I need help. This still took me 2 solid days to do. I can probably do it in less than a day now that I know what's involved. Remember how long it took you to do your first brake job? It's a snap now, right? Multiply that by 20. That's a timing belt.
I still had to do my homework. Watched a few youtube videos on how to remove that nut, buying the special tool, getting all the materials, gaskets, hondabond, etc.
Yes, if I can do it, anyone can. BUT... If you have never done it before be prepared for one of the biggest pain in the A _ _ jobs you can ever do on a car. I've swapped an entire engine in less time than it took to do my first timing belt. Getting in cramped spaces, busting knuckles, loosening and removing things that make no sense whatsoever, etc. If this is your daily driver, you are also under the gun to get it working before Monday too.
It's a daunting task. So get ready to commit - ALL IN or go home. Or to the mechanic, in this case. Good luck.
dosmastr
05-05-2015 12:19 PM
