Trouble Code P0497
Old 12-28-2009
brewcrewearl's Avatar
brewcrewearl is an unknown quantity at this point
Trouble Code P0497
I have a 2005 Honda Civic LX stock with no modifications(except stereo)
For the last few months my check engine light has been coming on and going off on its own. When it first came on I got it checked and the code was P0497. Before I could take it to the shop it went out. I tracked it over the next couple months and the light would come on when my car would get below 1/3 tank of fuel. After I would fill it back up it would go out a short time later. It slowly began to come on with my fuel tank at higher levels. So now its always on which makes it easier to troubleshoot. I had my codes read at autozone today and the guy told me I had a P0497 (EVAP system low purge flow). He also told me there was a P1496, but I believe that may have been stored in the reader from the previous vehicle. Has anyone run into this or a similar problem? Car runs fine, but I know something is not right, hence the light. I would like to fix it myself, don't have time to take it to the shop.
Old 12-28-2009
Pedro2598's Avatar
Pedro2598 is an unknown quantity at this point
Re: Trouble Code P0497
hmmm... possibly your charcoal canister!? it might be degrading!?
Old 12-28-2009
might be the purge valve is clogged or not working. the evap system unfortunately has many parts that can fail. alot of them are in the engine bay near the throttle body.
Old 08-22-2010
jtomas83's Avatar
jtomas83 is an unknown quantity at this point
i have the same problem. did you figure the problem out?
Old 10-18-2011
I tried the purge valve(it seems to be the easiest thing to change in the system) still has the same problem. Im not too worried about it at the moment because I don't see a change in my MPG and I can get the light to go out and pass emissions
Old 04-27-2017
Smiley3212's Avatar
Smiley3212 is an unknown quantity at this point
I'm having the same problem at 130k with an 05 civic. I see this post is old but maybe you got it fixed and learned what it was? A mechanic told me a smoke test might be needed?
Old 08-18-2021
LDAWG48's Avatar
LDAWG48 is an unknown quantity at this point
I know this thread is years old, but I’m having this same issue. Any luck?
Old 09-29-2021
user 7859's Avatar
user 7859 is an unknown quantity at this point
Same on a 2004 EX. So far I've replaced gas cap, evap canister, vent solenoid, and purge solenoid. Smoke test is next, but all those other parts were cheaper than the diag fee.
Old 09-29-2021
Colin42's Avatar
Received 1,126 Likes on 941 Posts
How about starting your own thread stating your issues and your troubleshooting steps?
Old 09-29-2021
user 7859's Avatar
Why a new thread? It's the same issue, and I've listed what I've done so far.
Old 09-29-2021
Colin42's Avatar
Because that's what you do.
Old 09-29-2021
user 7859's Avatar
So you can have 500 threads for the exact same thing? No, thanks. Do you have a solution, or are you here to Karen? Guess I should find a forum with fewer grumpy Canadians.
Old 09-29-2021
Click Here
FRSam's Avatar
Received 1,154 Likes on 901 Posts
Don’t let the door hit you on the way out!
Old 09-29-2021
Colin42's Avatar
I'm a moderator explaining the rules to you...
See ya
EMAN64
52
02-29-2020 06:08 AM
michelle6818
03-04-2012 06:53 PM
ZSKCivic01
07-21-2009 01:42 PM
fuledya
10-27-2006 03:39 AM
streetglower
01-18-2005 07:16 PM
Quick Reply: Trouble Code P0497
