A/c fan blower not working
Old 12-19-2009
hot in hawaii's Avatar
hot in hawaii is an unknown quantity at this point
I have a 04 Honda civic lx . A/C was working fine last night. This morning turned it on and fan wasn't blowing at all. Defrost not working too. Does anybody have a clue to what's going on here with my problem? Where shall i start to look?
Old 12-19-2009
CraigW's Avatar
Re: A/c fan blower not working
Search around the site, if the fan is not working at all search "transistor" something opens up on them (no one has said for certain what opens up I think it may be a thermal cut off)
It is a simple fix, I would not go with the resistor though... I would try to find out exactly what the open part actually is and get a replacement or replace the transistor as a unit.
Old 12-19-2009
if that doesnt work, may need a new blower motor which is usually cheap for a used one and easy to change.
Old 01-06-2010
Located blower heater transistor. Checked continuity. Open circuit found. Changed transisitor with new one ($45.00 from dealer). Now my wife is chillin in ride. Thanks guys couldn't do it with out you. By the way, the resistor went bad because there was very little air going through the very dirty, clogged, and fillty a/c in-cabin filter. Will not to forget to changed that every 12,000. Aloha braddahs...........
Old 01-06-2010
CraigW's Avatar
There is something that open on these units and causes loss of blower operation. I read once that it was a thermal cut off (can't confirm)
If the cabin filter was plugged it may have caused heat to build up and open the TCO. The transistor is cooled by the blowers air just like the old blower resistor units used to be.
Old 10-19-2010
roberje's Avatar
roberje is an unknown quantity at this point
AC fan was working fine last night and now it doesn't. Turn on the speed control switch and the fans come on for a few seconds and then they cut off? 2003 Honda civis
Old 10-15-2014
phanhoang16's Avatar
phanhoang16 is an unknown quantity at this point
Thumbs up Re: A/c fan blower not working
One day my honda civic 2002 A/C blower doesnt work anymore. Rearding on ur suggestions about blower fan resistor when the A/C blower stop working, i replace it and it work smoothly again.I would say thanks to u guys. some one say, when this happen, 99% because of ac blower fan resistor which a common issue for honda civic or accord.
mikemc422
08-09-2018 05:41 PM
ORskier
05-03-2015 12:54 PM
paulnguyen
04-20-2015 01:33 PM
prowl
04-18-2015 07:50 PM
Pir8pete
165
03-06-2009 05:16 PM
Quick Reply: A/c fan blower not working
