Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 2 Weeks Ago   #1 (permalink)
Warfrogs
New Member
Warfrogs is an unknown quantity at this point
Unhappy Installed Short Ram Air Intake - Now loss of acceleration and cuts out
Hi, first post and I wish it was a happier one.
Just bought a 2002 Civic EX Coupe (Automatic) and have been LOVING it. On my previous car I had installed a short ram air intake and enjoyed the increased gas mileage and power I got from it so since I was at 60k miles and needed to change out the air filter anyways, I decided to do it on the civic as well. Everything wasn't perfect, but when I ran to the auto parts store to get the last of what I needed, it ran fine. Got home, attached a new hose and an elbow, and now it loses all power and nearly cuts out when I give it any gas, followed by a high pitch whine and a hissing sound like air either escaping or being pulled in when I shut it off.
Before I say everything I did, let me say the short list of what I think the problem might have come from. I think it's either the sensor that sits inside of the intake, or else the hose that ran from the intake to the engine. My reasons are as follows.
As I went along with my e-bay intake, I ran into a few problems. The hose that was attached to the engine from the original intake didn't fit as the place that it fit on was smaller than the original hose. I used a bit of the included hose from the filter and fit it inside of the new vacuum hose which was the same size as the original hose and made it fit. I didn't think that the small amount of air loss would be a big deal, but it's a possibility, and if so, is there anything I can do to fix this short of putting the original intake back in?
Now here's what I'm worried about... I'm pretty sure it's just a temperature sensor, but if not, I'm in it deep. As I was pulling out the original box, I didn't see that sensor and it yanked the wires out from the module itself. I disassembled it as best I could and put a bit of wire in. I think that the wires are loose and are falling out, and I'm worried that that is the root of my problems and I don't know the part number, name, or cost. Furthermore, I found that the wires didn't reach to the place that the sensor had to go in on the new intake so I got a bit of wire of the same gauge and spliced them together (not ideal, but only temporary).
If need be, I can hop in my car and record the sound and everything, but I can't even generate enough power to get it up my driveway and into my garage. Any advice is VERY appreciated.
EDIT: Sorry, but I just realized this sounds a lot like a vacuum leak. Would I be right in thinking that?
Warfrogs is offline   Reply With Quote
Sponsored Links
Old 2 Weeks Ago   #2 (permalink)
unTuned
Super Member
unTuned's Avatar
unTuned is a jewel in the rough unTuned is a jewel in the rough unTuned is a jewel in the rough
Send a message via MSN to unTuned
Re: Installed Short Ram Air Intake - Now loss of acceleration and cuts out
first thing is first. when you installed your new intake, did you let the car idle on its own and relearn the new settings? youre supposed to do this with an intake/header/exhaust install. disconnect the battery for 10-15 minutes so the ecu resets, reconnect and turn the car on. when you turn the car on dont touch any pedals or anything. just turn it on and get out and leave it for 10-15 minutes to relearn all the new levels.
that hissing sound is nothing, its just a nice 'feature' you get with the intake. since it is carrying a lot more 'open' airflow compared to the stock airbox, its continuously sucking air in, and when you shut the car off, the air being sucked is suddenly cut off and thats the hiss sound. thats normal for a sri.
as for the little hose going from the engine to the intake, that should be fixed asap, but that wont be your problem either. thats the breather hose and once i had one that was too short and it would slip off now and then, but my car still drove fine even when it had slipped off. it just helps vent bad gases in the engine. i just went into the part store and got a hose that i kind of had to force in place, but it fit fine and any hose will work. theres not really any heat exposed to it so you dont need a super high tech hose. any rubber/silicone hose will fit. i used one that normally is used for a radiator.
there are a few things that could be the problem. after i read the stuff about you basically breaking and fixing the sensor, i would say that is possibly the problem. they can be fragile sometimes, and i would call the dealership and see what a replacement sensor costs. if its cheap i would pick one up and try that out and see what happens. if its expensive, i would remove my aftermarket intake, and reinstall the stock intake with the same sensor to see if you have the same problem. at least that way youll know its a good chance the sensor is toast. then you have a good reason to go buy it.
if you can though a pic of your engine bay with the current setup would help. it might be something i just see right away.
__________________
HP 4-1 race header - AEM Short ram intake - Tsudo N1 2.5" catback system - NGK Iridium IX spark plugs - OBX Racing strut tower - 4 ga. ground kit - Drag DR-19 17" rims - Kumho Ecsta AST 215/45/r17 tires - 8000k HID kit - Varad led custom street lighting - McMaster trunk shock kit - Pioneer deh-p5900ib deck - Alpine Type-S 12" sub - Phoenix Gold mps-2500 amp - Infinity Kappa 692.9i 6x9 speakers
unTuned is offline   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
turbo zombie
New Member
2005 Honda Civic
turbo zombie's Avatar
turbo zombie is an unknown quantity at this point
look on estore.honda.com. once you go through a couple of steps you can look at all the parts you want. i looked at the air intake section for your car, the only thing i see is 011, "sensor assy., air temperature." that runs about $35. the problem might be the wiring though, since you said it pulled out of the connector. if it pulled out of the harness connector and not the sensor, i think your best bet would be to try and go to a junkyard and get the harness connector, and splice that in.
__________________
Current:
2005 Civic Lx Coupe, auto
Previous:
1985 Volvo 245, 5 speed (avatar)
1984 Ford Festiva, 4 speed
1979 Volvo 242, 2.3 turbo, auto
1986 Volvo 245, 5 speed
turbo zombie is offline   Reply With Quote
Tags
7th , air , change , check , civic , engine , exhaust , gen , honda , intake , light , pictures , ram , sensor , short , sound
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
