Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-10-2009   #1 (permalink)
DjExotic
New Member
DjExotic is an unknown quantity at this point
no cat and having lil problem on hp
i just got this car and i notice first off after two days of buying the car off the used dealer. i was gettin slow hp on the highway. and the engine light came up. i had the car scan and came up with the p0420 code of the cat. so i look at the motor to the headers (their are aftermarket header on this car) but when i look under the car, their is no cat so i been running without the cat for almost a week now.
so should i order the cat or just the o2 senor and then get the cat later that week.
need help real soon.
DjExotic is offline   Reply With Quote
Sponsored Links
Old 10-10-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: no cat and having lil problem on hp
well you need a cat otherwise the engine light will always be on. it wont really affect how the car runs, its just there to clean the exhaust gases. the second sensor in the cat tells the ecu if its working properly. does not affect performance.
__________________
________________________________________
Restore Performance, Reduce Costs
www.lubecontrol.com
LC20 - go 10k miles on a single oil change
Go Here For Real Medicine
http://www.youngliving.com
Member 1025782
The DX-Resource
http://bellz.sqweebs.com/
gearbox is offline   Reply With Quote
Old 10-10-2009   #3 (permalink)
DjExotic
New Member
then how come when i try to punch it on the highway it lagging to get up to speed.
Old 10-10-2009   #4 (permalink)
gearbox
Super Moderator
could be a combination of things. maybe just needs a tuneup. and the car isnt fast to begin with.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 10-10-2009   #5 (permalink)
ronaldo9
Platinum Member
ronaldo9's Avatar
ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned
Send a message via AIM to ronaldo9
Make sure you are not in limp mode for whatever reason. FYI you will run a bit leaner w/o the cat.
ronaldo9 is offline   Reply With Quote
Old 10-10-2009   #6 (permalink)
DjExotic
New Member
well, i going to put the cat in and the 02 with it come in the shop and going to do the tune up since it have 138k.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Timing Belt DIY 2
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Transmission - Jerky - Automatic - HELP!
Warrenty law that Save's your a$$
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
