Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-14-2009   #1 (permalink)
brian02
New Member
brian02 is an unknown quantity at this point
best brand spark plugs to use
What is the best brand of spark plugs to use? 02 civic..
whats the gap spec?
thanks
brian02 is offline   Reply With Quote
Sponsored Links
Old 09-14-2009   #2 (permalink)
ronaldo9
Platinum Member
ronaldo9's Avatar
ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned
Send a message via AIM to ronaldo9
Re: best brand spark plugs to use
NGK or Denso imo, they normally come pregapped but I have to look up the factory gap spec.
ronaldo9 is offline   Reply With Quote
Old 09-14-2009   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
NGK v-power are excellent and only $2 each. they are copper so you should change them every couple years to keep good performance. if you have money to waste, ngk or denso iridiums are also good and will last a bit longer. no extra performance, but they will use slightly less energy to make the same spark so your electrical system works less. do not use any brand other than denso or ngk for a honda.
__________________
________________________________________
Restore Performance, Reduce Costs
www.lubecontrol.com
LC20 - go 10k miles on a single oil change
Go Here For Real Medicine
http://www.youngliving.com
Member 1025782
The DX-Resource
http://bellz.sqweebs.com/
gearbox is offline   Reply With Quote
Old 09-18-2009   #4 (permalink)
01civictune
New Member
01civictune is an unknown quantity at this point
pulse plugs they are just expensive
01civictune is offline   Reply With Quote
Old 09-18-2009   #5 (permalink)
gearbox
Super Moderator
pulse plugs are a scam. i tried and returned them after one test drive. many others have had them fail, crack, ruin the engine, misfires, etc. just search around the net. took me 30 days to get a refund after finally threatening a credit card chargeback. half the time they dont even answer the phone. performance was worse than $2 ngk copper plugs.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 09-22-2009   #6 (permalink)
HONDAHUMPER
New Member
HONDAHUMPER is an unknown quantity at this point
lol NGK ftw! dont use bosch heres what happend to the last one i had in my 03 ex.. the gap is .042
HONDAHUMPER is offline   Reply With Quote
Tags
01 , 2006 , 2007 , brand , civic , forum , hoda , honda , ngk , plug , plugs , problems , recommend , si , spark
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Timing Belt DIY 2
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Transmission - Jerky - Automatic - HELP!
Warrenty law that Save's your a$$
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
