Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-05-2009   #1 (permalink)
mdn217
Member
mdn217's Avatar
mdn217 is an unknown quantity at this point
HELP! Squeaking noise coming from driver side wheel area.
I was coming home from the store earlier today and my car began to make a high pitched squeaking noise. it sounded as if it was coming from the front drivers side wheel area.(The noise was only there when the car was moving..) After i got home, i noticed that the front drivers side wheel was very hot, a lot hotter than the others. and there was an odor coming from that side.(almost like a metal on metal smell?) If anyone could give me any possible solutions to this problem or at least diagnose it i'd really appreciate it...
Thanks
mdn217 is offline   Reply With Quote
Sponsored Links
Old 08-05-2009   #2 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
Re: HELP! Squeaking noise coming from driver side wheel area.
Dust sheild? Rotor? Bad bearing maybe? It could be almost anything take it off and take a look in there it should be really apparent on what it is.
04 Honda Civic is offline   Reply With Quote
Old 08-05-2009   #3 (permalink)
mdn217
Member
mdn217's Avatar
I made sure the dust shield wasnt rubbing. I even bent it away even more and the noise is still there... how can i tell if the rotor or bearing is bad?
Old 08-06-2009   #4 (permalink)
kcari
Ultimate Member
kcari's Avatar
kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all
Send a message via AIM to kcari
if your rotor is bad then when u brake u might feel pulsation in the pedal You might also hear noise. a bearing is bad if you jack the car up, give the wheel a spin and still hear the noise- plus ur wheel might be wobbly too. maybe new brake pads?
__________________
http://www.youtube.com/watch?v=Ya-bq3zokeU
^ EPIC EM2 VIDEO!!!
My EM2 is MAD FAST YO;
Cars that I've smoked
- Smart, Prius, Fit, Yaris, Aveo.
kcari is offline   Reply With Quote
Old 08-06-2009   #5 (permalink)
mdn217
Member
mdn217's Avatar
i think i found the problem...brake pads. the pad is not even visible in the caliper on the drivers side...im guessing the pad is shot. i am going to replace them tomorrow and see if that solves the problem. Any recommendations on break pads?
Thanks for the replies
Old 08-06-2009   #6 (permalink)
kcari
Ultimate Member
kcari's Avatar
ceramic pads are nice. but oem is just fine
__________________
^ EPIC EM2 VIDEO!!!
Old 08-06-2009   #7 (permalink)
04 Honda Civic
Super Member
OEM is good. Make sure your rotors are smooth before replacing the pads or it will sqeak down the line and probably be crappy braking.
Old 08-06-2009   #8 (permalink)
mdn217
Member
mdn217's Avatar
caliper was froze....
Old 08-08-2009   #9 (permalink)
04 Honda Civic
Super Member
ouch..grease and clean your slidepins every time you do your brakes.
Tags
2004 , 2005 , 2007 , belt , civic , coming , driver , drivers , honda , noise , side , squeak , squeaking , timing , wheel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
