Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-04-2009   #1 (permalink)
Merv
New Member
Merv is an unknown quantity at this point
Car Hesitates/Misses when A/C is on
I have a 2001 DX sedan 5sp. When I turn on the A/C the car seems to hesitate or "miss" while driving. When A/C is turned back off car runs normal. A/C works fine.
Anyone heard of this hesitation or missing with the A/C on?
Thanks.
Merv is offline   Reply With Quote
Sponsored Links
Old 07-04-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Car Hesitates/Misses when A/C is on
well i feel alot of hp being robbed, which is normal. not sure what you mean by missing. maybe you have a loose belt or something.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 07-05-2009   #3 (permalink)
Merv
New Member
Quote:
When the A/C is on and I drive down the road while steady on the gas, the car will hesitate or stutter every 30 seconds to a minute. If depress the gas pedal, there is again some hesitation until the revs get higher. I know what you mean with a loss of power with the A/C on, but this is different. It does not remain at a smooth constant when the A/C is on.
Hope this makes sense. Thanks for your help.
Old 07-05-2009   #4 (permalink)
Jp7
Member
Jp7's Avatar
Jp7 is an unknown quantity at this point
Send a message via AIM to Jp7
I dynoed my CT with the AC on once (by accident) and lost 40 or so HP. I was like "WTF", really getting frustrated when I knew I had no knock, good timing and good AFR. I saw the switch on and I was like "OMG i'm such a n00b", turned it off, instant +40HP. LOL.
I normally have 11-9 inches of vacuum at idle with no AC, but it drops to about 7 inches with the AC on. Huge difference.
Do you have a vacuum gauge? Every car should have one. You can really see what is going on. A good running naturally aspirated engine should have about 17-19 inches of vacuum, if you have a 'stock like' setup. You may have a vacuum leak, causing the measured/calculated AFR to be off.
__________________
Mitsubishi Lancer Evolution IX MR CT9A (600+BHP/Self Tuned -My old Dyno Video Click Here)
Ford Ranger Edge PN150 3.0 V6 RWD (The Lights & Sound Machine)
Ford Ranger PN150 2.3 I4 RWD (Stock)
Mazda Rx-8 SE3P Single Turbo (Sold)
Mazda Rx-7 FD3S Single Turbo (Sold)
Mazda Rx-7 FC3S Twin Turbo (Sold)
Jp7 is offline   Reply With Quote
Old 07-05-2009   #5 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
standard vacuum on a honda is around 22 inches, but with such a small engine its a large draw for ac to be on, its normal
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 07-05-2009   #6 (permalink)
batman900
Member
batman900 will become famous soon enough
What your feeling is I believe the alternator kicking on and off while your driving. Mine does the same thing and always has. Also with AC on when I go from a stop in first gear I get a bad hesitation while letting the clutch out. Our cars are weak and the AC kicks their butt.
Nothing wrong with your car.
batman900 is offline   Reply With Quote
Old 07-05-2009   #7 (permalink)
gearbox
Super Moderator
you mean a/c compressor? yeah mine does that too. as soon as it kicks in, the car shakes and all the hp goes away while driving. they when it kicks back off, power comes back.
__________________
www.lubecontrol.com
Member 1025782
Old 07-05-2009   #8 (permalink)
greeen01civic4d
balls in ur mouth
its called parasitic draw, and most newer cars have it setup so that under wot the ac clutch disengages and power comes back when needed
__________________
Old 08-19-2009   #9 (permalink)
civiboy
New Member
civiboy is an unknown quantity at this point
I have the same problem with my 99 plus when at idle everytime the compressor kicks in and my rpm's drop my air goes from cold to warm. I was thinkin if i got a voltage stabilizer would that help?
civiboy is offline   Reply With Quote
Old 08-19-2009   #10 (permalink)
Ckutch02EX
Member
Ckutch02EX's Avatar
Ckutch02EX is an unknown quantity at this point
Send a message via AIM to Ckutch02EX
^That's normal. Put the air on fullblast at an idle with the lights on. Instant dimage and less air. Sit at an idle and hit the gas. The air gets colder till your tac hits normal idle then it dies again.
__________________
Old School
Ckutch02EX is offline   Reply With Quote
Old 08-19-2009   #11 (permalink)
gearbox
Super Moderator
compressor works best at higher rpm like 3k. at idle it doesnt do much.
__________________
www.lubecontrol.com
Member 1025782
Tags
09 , 2007 , ac , car , civic , ford , hesistates , hesitates , hesitation , honda , misses , runs , shakes , start , turned
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
