Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-02-2009   #1 (permalink)
pantchilev
New Member
pantchilev is an unknown quantity at this point
Question Engine problem
Hi,
When I started the car one day there was a noise like from loose belt then despaired? I kept driving my car and suddenly the engine stop. I waited half an hour and then I was able to start again but even if I press the gas to the floor I couldn't go more than 40 km. Obviously something was seizing ( suspected alternator or a/c compressor).
Also the key light is ON. I towed the car to my mechanic and he said that the catalytic convertor was red and the car was working reach. Then he tried to connect the diagnostic tool to read the code from my computer (the engine light was on) and the message was 'Check Connector'.
He tried on different car and the diagnostic tool was working but does not want to connect on mine. I'm sure it works because we used it three months ago when we changed the timing belt and was able to read the codes from the car.
Please, give me some suggestions and possible solution.
Thank you in advance,
pantchilev is offline   Reply With Quote
Sponsored Links
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
