Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-28-2009   #1 (permalink)
The RedheadPimp
New Member
The RedheadPimp is an unknown quantity at this point
Battery wont hold charge
Alright so here is what happened. I was driving down the highway a few days ago and the battery died while driving cause the car to shut off on me no matter how much i put the throttle to the floor. I replaced the battery about 16 months ago so i figured it was still good. I went ahead and bought a 100% new alternator and installed it, charged the battery. Everything seemed fine so i decided to take it out and it died after about 90 min of driving. I thought maybe my ground from the battery was bad so i went and replaced the terminal and wire and wet sanded the spot where the terminal wire mounts onto the engine and replaced the ground from the engine to the front frame. I am still having problems and it is quite frustrating. I took the car down to a local advance auto parts and they hooked a machine up to check my system. The reader came back with results saying that the battery was good and the alternator was good. It says i have a small drain tho, o.o2 A. I am running 2 amps to power my 4 12" subs in the car but have had them in the car for well over a year now and this is the first problem i have had. Both amps are connected directly to the battery with a fuse in the line. I am at a point where I dont know what to do. Any suggestions? To remove this ad, register today for free or log in if already registered!
The RedheadPimp is offline   Reply With Quote
Sponsored Links
Tags
90 , alternator , battery , car , charge , civic , dies , hold , honda , problem , wont
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
