Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-27-2009   #1 (permalink)
Newjd2
New Member
Newjd2's Avatar
Newjd2 is an unknown quantity at this point
Steering Wheel Shaking
I've brought my car to Honda and a Meineke and neither place can figure it out. My steering wheel shakes, but only after the car heats up. It isn't any of my motor mounts because they've all been checked. It only does it when I'm stopped at a light or something. I don't have any idea what it is so if anyone has any ideas I'd appreciate it. To remove this ad, register today for free or log in if already registered!
__________________
..The Kid G.I. #2..
Newjd2 is offline   Reply With Quote
Sponsored Links
Old 06-27-2009   #2 (permalink)
kcari
Ultimate Member
kcari's Avatar
kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all kcari is a name known to all
Send a message via AIM to kcari
Re: Steering Wheel Shaking
bushings? power steering fluid levels? axles in the front? something's bent?
__________________
http://www.youtube.com/watch?v=Ya-bq3zokeU
^ EPIC EM2 VIDEO!!!
My EM2 is MAD FAST YO;
Cars that I've smoked
- Smart, Prius, Fit, Yaris, Aveo.
kcari is offline   Reply With Quote
Old 06-27-2009   #3 (permalink)
tbohar
Senior Member
tbohar's Avatar
tbohar is on a distinguished road
Is it related to a rough idle??? Clean your throttle body sensors and such and such. That might help. Does the car feel like it wants to stall?
tbohar is offline   Reply With Quote
Old 06-28-2009   #4 (permalink)
Newjd2
New Member
Newjd2's Avatar
No, not at all. The car is quiet except the steering wheel shakes/ vibrates which in turn my exhaust will move somewhat causing some sounds, but the annoying part is just the steering wheel shaking. I'm stumped. If it helps I have an aem short ram intake, but I don't see that affecting my throttle body.
__________________
..The Kid G.I. #2..
Old 06-28-2009   #5 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned
Send a message via AIM to lordhelmet
Does it shake when your sitting still or moving?
__________________
I click on civicDave's links no matter how broken they are!
lordhelmet is offline   Reply With Quote
Old 06-28-2009   #6 (permalink)
tbohar
Senior Member
tbohar's Avatar
The only thing I can think of is what you have already covered which is motor mounts. or Idle which is probably not the problem. Hmmm. Have your transmission checked? Is it auto or manual?
Old 06-29-2009   #7 (permalink)
Newjd2
New Member
Newjd2's Avatar
I have a manual...and it's only when I'm stopped at a light...Doesn't seem to be shaking at all while driving...I appreciate all the help...I'm just as stumped....I might have the motor mounts checked out again...You never know...
__________________
..The Kid G.I. #2..
Old 06-29-2009   #8 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Does it happen all the time when stopped, or just when the fan kicks on?
TRIZ is offline   Reply With Quote
Old 06-29-2009   #9 (permalink)
Newjd2
New Member
Newjd2's Avatar
both....after booting up the car a couple minutes later it will start the shaking...from 3-5 minutes after ignition all the way up to turning off the car....it happens whenever I'm stopped...
__________________
..The Kid G.I. #2..
Old 06-29-2009   #10 (permalink)
tbohar
Senior Member
tbohar's Avatar
It's not likely for a manual transmission to cause this, I'd check the mounts yourself. Just start the car and rev it from the throttle body. Check to see if you can hear anything and see how much movement the engine has. The 7th gen civic has a mount that has a high wear rate that you might want to look into as well. It's posted all over the forum here.
Old 06-29-2009   #11 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
im sure its a low idle issue causing the engine to shake and you feel it in the steering wheel. clean the intake system and throttle body sensors.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Tags
96 , belt , civic , driving , honda , idling , noise , rough , shake , shakes , shaking , steering , timing , wheel , work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
