Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-27-2009   #1 (permalink)
beefstew226
New Member
beefstew226 is an unknown quantity at this point
Exclamation How to change 2003 honda civic ex distributor cap and rotor
I'm trying to find out how to change my distributor cap and rotor. Any adivice is greatly appreciated!!! To remove this ad, register today for free or log in if already registered!
beefstew226 is offline   Reply With Quote
Sponsored Links
Old 06-27-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: How to change 2003 honda civic ex distributor cap and rotor
youre already done! 01+ civics do not use a distributor based ignition. they have upgraded hi energy coil packs that go over the spark plugs and never need to be changed under normal conditions.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 06-27-2009   #3 (permalink)
beefstew226
New Member
Quote:
well that was easy!!! your awesome!!! thanks
Old 06-27-2009   #4 (permalink)
tbohar
Senior Member
tbohar's Avatar
tbohar is on a distinguished road
+1 for GBox. I knew there was no distributor but I also always wondered if there were any other parts that had to be replaced as regular maintenance. I know the car also has no ignition wires but does the boot that connects to the spark plug have to be replaced?
tbohar is offline   Reply With Quote
Old 06-28-2009   #5 (permalink)
gearbox
Super Moderator
that boot is the whole coil pack, and it does everything that wires/distributor/boots do on an older car. either it works or it doesnt, and believe me you will know if it breaks. theyre rated to last the life of the car. only thing that needs changing are spark plugs.
__________________
www.lubecontrol.com
Member 1025782
Old 06-28-2009   #6 (permalink)
gearbox
Super Moderator
__________________
www.lubecontrol.com
Member 1025782
Tags
1999 , 2000 , 2001 , 2002 , 2003 , cap , change , civic , distributor , honda , ignition , plug , rotor , rotors , spark
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
