Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-26-2009   #1 (permalink)
babzog
New Member
babzog is an unknown quantity at this point
"Growl" from engine at 3-4k rpm.
Hey folks,
Recently (as in, within the last month), I've been noticing a different "note" from my engine as the rpms drop between gear shifts (or, to a lessor degree, when I just rev it). Sounds kinda like a growl or a gargle (get that little flap thing at the back of your throat moving - that's pretty much what it sounds like .. LOL).
As this is new, I'm concerned as to what it might be.
Thanks!
babzog is offline   Reply With Quote
Sponsored Links
Old 06-26-2009   #2 (permalink)
robber
New Member
robber's Avatar
robber is an unknown quantity at this point
Send a message via ICQ to robber
Re: "Growl" from engine at 3-4k rpm.
I had something similar not too long ago, ended up being the heat shield on my Cat Converter. Have someone rev the engine while you get under the car, see if it comes from there, and look for signs of rust on it.
I just took it off, sound gone.
robber is offline   Reply With Quote
Old 07-06-2009   #3 (permalink)
mdawg
Senior Member
mdawg is on a distinguished road
You know mine makes a similar noise. When I am around 4k I hear what sounds like a rattling metal noise, but anywhere below or above its gone. When I am on the interstate I like to run aroun 80mph but that puts my rpms right in that area and the engine gets really loud but if I do 90 and bring the rpms up some more its 10 times quieter. Weird.
__________________
New Ride:
2k1 EM2 Coupe EX 5 Speed
Current Project:
CarPC
Xenarc 700TS 7" Touchscreen
1.2Ghz Celeron
Asus Mobo
512mb Memory
120GB HD
150wat PS
Custom Built Startup/Shutdown Controller
mdawg is offline   Reply With Quote
Tags
automatic , belt , civic , engine , growl , growling , honda , noise , rpm , timing , transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
