It's not the relays, I have even switched them with a working set from my RSX that uses the same relays and it didn't start.
YLW/RED goes to ECM and has 12v with ignition on.
BLK/WHT has 12v with iginiton on.
YLW/BLK is grounded and goes to ignition.
When I close the contacts on the relay,and the ignition is on, it sends 12v to the ignition via the YLW/BLK wire. When this happens, the battery indicator and CEL come on and im able to start the car and keep it on as long as i keep the relay closed.
Any reason why it wont close by it's self? All three(rsx orig, civic orig, new) ecm relays work on my rsx. Are the voltages correct?
