Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-11-2002   #1 (permalink)
Gordo61616
Member
Gordo61616 is an unknown quantity at this point
Front drivers side rattle when hitting bumps
lately i've notice that when i hit bumps with my 2k1 ex coupe that the front drivers side rattles. i checked the strut to see if it was blown and it seems not to have been. any ideas what it could possibly be?
thanks
gordo
Gordo61616 is offline   Reply With Quote
Sponsored Links
Old 04-11-2002   #2 (permalink)
HCivic
Member
HCivic is an unknown quantity at this point
Send a message via ICQ to HCivic
is this coming from the outside or inside or ur car?
if it's from the inside on the door panel, then it is a common problem for the 2k1s
HCivic is offline   Reply With Quote
Old 04-12-2002   #3 (permalink)
MrFatCat
Member
MrFatCat is an unknown quantity at this point
I have the similar problem on the driver side door as well. The rattle sounds so close to my ear and it is getting worse when the moonroof is opened. I am not sure the rattle is actually from the door panel or around the seat belt area. Does anyone have the same problem? Any suggestion for me?
MrFatCat is offline   Reply With Quote
Old 04-12-2002   #4 (permalink)
FamilyMan
Member
FamilyMan is an unknown quantity at this point
There is a technical service bulliten out at Honda on the door pillar rattles. My pillars don't rattle, but my drivers door trim does. It is annoying. Unfortunately with lowering springs that will happen.
Visit: teamgoodnews.com
My Rice
FamilyMan is offline   Reply With Quote
Old 04-12-2002   #5 (permalink)
Dr5D
Post Master General
Dr5D's Avatar
I just seem to be hearing more noise in general from my drivers door area, i cant really lean over and hear the passenger side tho
Dr5D is offline   Reply With Quote
Old 04-13-2002   #6 (permalink)
OyD
Diamond Member
OyD's Avatar
OyD is an unknown quantity at this point
I get a knocking noise when i go over bumps. I get the same noise when I'm turning my steering wheel. I happens at the same point every time. I've had my car into honda 3 times now and they still can't figure out what is wrong with it.
OyD is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Timing Belt DIY 2
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Transmission - Jerky - Automatic - HELP!
Warrenty law that Save's your a$$
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
