Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-21-2009   #1 (permalink)
Herbie1964
New Member
Herbie1964 is an unknown quantity at this point
Limp Home Mode
Hi Civic Fans... My Partner has a 7th Gen 1.7CTDI with 50K miles on the clock. For the last 6 months she has been ringing me about once a month as she has broken down on the way to work. She tells me it loses power when going up hill and mostly when it's a cold engine. For the first time today i was able to replicate the problem, I realised that the car is going into LIMP HOME MODE. If you turn off the ignition and remove the key, then restart the engine it will go trouble free for several weeks without a problem!!!!!!!!!!! We called the AA and the patrol could not find any codes. There has been NO CEL light on at all... Hence no reason to generate a code... When limp home mode is entered the engine will not rev past 2000 rpm with no other indication of a problem.
Engine oil level is at max and all other levels etc are fine, Fuel filter changed last week to eliminate, this is before i knew that the loss of power was due to" limp home mode", No codes or engine lights ...... and yes the bulb works, 'cos at position II when the dashboard lights come up the light is on as in normal operation...
Today i visited another Honda dealer and they said that not all sensor and operational failures generate a code!!!!!!! Oh great, and i thought that these lights and all the electronics in modern cars were supposed to help apart from being expensive for the owner!!!!!!!! They did however tell me that they had had the same circumstances and chose to change the crankshaft sensor, which on the 04 plate civic must have solved the problem cos that was a week ago and the customer hadn't been back..... The next advice was if this doesn't work there is always the engine temp sensors and the crankshaft sensors, but these are more likely to give an engine code...
Ok , so now i have a partner who has been wound up over a six month period with neither me or the garages believing her that there was ever a problem, 'cos we all rely on the little engine light and codes to tell something is wrong!!!! Is there anyone out there who really knows their stuff and can maybe advise on generic methods for checking these sensors before resorting to main dealer mentality and spending loads of money on one sensor after another. Ps the crank sensor is £78 +vat, havent priced the others yet!!
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Herbie1964 is offline   Reply With Quote
Sponsored Links
Old 04-21-2009   #2 (permalink)
jameslinkinpark
Senior Member
jameslinkinpark will become famous soon enough jameslinkinpark will become famous soon enough
Re: Limp Home Mode
I wish I could help you, but I'm just wondering why you would let this go for 6 months without getting it checked out until now.
jameslinkinpark is offline   Reply With Quote
Old 04-21-2009   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Limp Home Mode
if theres no code and its mysteriously losing power, thats a hard problem to figure out. could be all sorts of things including a clogged catalytic converter.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 04-21-2009   #4 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
Re: Limp Home Mode
there are probably codes there, but some obdII code "readers" cannot pull. dealer is the only one who can tell u what it really is
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 04-21-2009   #5 (permalink)
DieMaster
Senior Member
DieMaster's Avatar
DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light DieMaster is a glorious beacon of light
Re: Limp Home Mode
does the CEL come on when u turn on the ignition? could be the light was on and the bulb burned out or more likly he cut the wire so it would shut off.
DieMaster is offline   Reply With Quote
Old 04-22-2009   #6 (permalink)
Herbie1964
New Member
Re: Limp Home Mode
Quote:
Cos when there is no dash light coming up , no recorded codes on OBDII that can be found by the AA man and his laptop or the Honda Dealer. My misses just got more and more frustrated and more and more people pointed at the women driver thing!!! It was only yesterday when it happened to me that i was able to work out that it had gone into limp home mode, the rev counter and rev's stuck at 2000 rpm.
It was not me being irresponsible with my partners safety, but the fact that it had only happened to her!
Old 04-22-2009   #7 (permalink)
Herbie1964
New Member
Re: Limp Home Mode
Quote:
Hi Gearbox, was rather hoping that you would look at this as it looks like you have a bit of a rep on this site for being a man who knows!!!!
Can i just go over a few points... Going up hill, revs stuck at 2000 rpm, Limp home mode realised yesterday. Car will run for weeks with no problems and no OBDII codes.
Yesterday i had a long converstion with the service manager of a large honda dealer in Surrey UK. He told me that all codes could be seen by roadside patrol or dealers the same. The only difference would be in some cases the actual code... which would just be identified buy the software used on the laptop software concerned.. He, as in my original mesg said that under some circumstances some sensors may not declare codes in intermittent circumstances. He said that anything to do with emmissions would declare a code! This would be Lambda sensor problems etc where the fuel mixture is altered by the ECU engine managment system. However, our Civic runs for weeks without a problem and this main dealer has told me he would change
1. Crankshaft sensor (by the starter item 7 on parts list)
2. Engine temp sensors
3. Crankshaft sensor
In this order? crankshaft sensor 1st i was told..... There is at least £ 300 of parts here and as a trained engineer i dont like fitting parts without getting to the root of the problem...
How can i check this out...... very difficult i know ...... but we cant be the only failure? The dealer told me they had one exactly the same last week...
Does anyone have principles of operation for this from Honda? Anyone know a Honda tec would can help?
Gearbox .... thanks for listerning... thought id give you a real challange rather than somethings you've been asked...
Old 04-22-2009   #8 (permalink)
Herbie1964
New Member
Re: Limp Home Mode
Quote:
Yeah.. agreed but the AA and RAC have equiptment that is equal to the dealers and im told by a dealer that all these 3 have exactly the same ability unlike a cheeper version from ASDA / walmart or Argos??
Old 04-22-2009   #9 (permalink)
Herbie1964
New Member
Re: Limp Home Mode
Then when the engine starts the light goes out as in normal condition and operation......
Old 04-23-2009   #10 (permalink)
wallydude03
Senior Member
wallydude03's Avatar
wallydude03 will become famous soon enough
Send a message via AIM to wallydude03
Re: Limp Home Mode
If i were you i would disconnect the battery and then reconnect it after an hour or so so that the ECU will relearn its settings. Maybe then it can detect something wrong and throw a check engine light at you.
wallydude03 is offline   Reply With Quote
Old 04-23-2009   #11 (permalink)
Herbie1964
New Member
Re: Limp Home Mode
Quote:
Thats not a bad idea... Does the ECU behave like any other PC? When connected to the 12 Volts i suppose it has some low level memory storage?
The old POPO power off power on may have its merit... Will try this... and make sure i find the stereo code first!!
Old 04-23-2009   #12 (permalink)
gearbox
Super Moderator
Re: Limp Home Mode
the thing is all of those sensors have engine codes for when they malfunction. so i doubt replacing them will do any good. and if the car drives fine some of the time, there is no way its a bad crank sensor (the car would just shut off after you try and start it). the ECT (engine coolant temp) sensor does control alot of critical engine functions. if it has failed and the ecu thinks the engine is always cold, you will have a very rich fuel mix and retarded timing even when the car is warm, which can cause serious problems like power loss. so that might be worth replacing because its so easy to change right above the thermostat housing.
__________________
www.lubecontrol.com
Member 1025782
Old 05-15-2009   #13 (permalink)
Herbie1964
New Member
Re: Limp Home Mode
Hi Civic fans!!
There has been a development.... P1236 ..... It means that there is either high or low pressure problem on the output of the high pressure pump (Diesel pump). Googled P1236 and Im not the only one with this problem..
Check this out http://www.ilexa.co.uk/forum/index.php?topic=18632.0
This is a bit of what i have found......
Civic 1.7 diesel 2003 code P1236 any one?
« on: 17:16 12 06 2008 »
Hi all
have exhausted my P code web sites, anyone know this P1236--its also been flagging boost/map sensor low volts - this has been replaced, runs bad under max load
cheers
This seems the same as my problem cos it also suffers from loss of power under load ie "going up hill" Still no nearer though cos it sounds like it could be anything from turbo to vacuum valve or sensors?
Found another good lot of people with the same story... checkout http://www.usedcarmart.co.uk/forum/s...ad.php?p=81087
Any ideas yet as ive stuck some deisel redex in it and havent seen a problem for 3 days?
Old 05-17-2009   #14 (permalink)
Colonel Panik
New Member
Colonel Panik is an unknown quantity at this point
Re: Limp Home Mode
Diesel?
Colonel Panik is offline   Reply With Quote
Old 05-17-2009   #15 (permalink)
wallydude03
Senior Member
Re: Limp Home Mode
http://www.civinfo.com/forum/previou...p-1-7ctdi.html
Maybe that will help you out. I never heard of a turbo diesel civic engine. I thought they were all gasoline
Tags
17cdti , 2001 , civic , crv , fix , home , honda , limp , maintenance , mode , schedule
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
