Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-02-2009   #16 (permalink)
Herbie1964
New Member
Herbie1964 is an unknown quantity at this point
Re: Limp Home Mode
Yes .... Diesel Heavy oil!! Like the trucks or Rigs? I think you call them... In the UK fuel is very expensive because the UK goverment take the ****** out of us with about 80% tax... £1.05 per Litre x 4.52 gives you an imperial gallon which is just a bit bigger than the Texan one... HaHa This means we pay at the pump between 7 and 8 dollars a gallon.... you get 1/3 more miles to the gallon over a petrol. The 1.7 CDTI Civic is based on the 1.7 Opel astra GM engine from the 90's...
Anyway this is just a note to let you all know the answer!!!!!!!!!!!!!!!!!!!!!!!!
After laods of grief we came across a Honda dealer who said he thought he had read somthing about the P1236 code...... Good Guy!!!! Apparently it can be associated with other codes in the range P 2035---2039... £1663.75 + labour of 2.5 hours.... please you can work that into dollars!!!!! BUT HONDA DID IT FOR FREE!!!!!!!!!!!!!!! This is a knnown problem by Honda and they have extended the warrenty from 5 years to 7 years.. It is all to do with the air intake jets in the varriable vien turbo being too small ... only 50 microns.. but when they block up it does matter!!!! nearly £2000 of it matters...
Thank you Honda, just wish all your dealers were as sharpe as this one!!!!!!!
Now i would buy another Honda cos my nightmares have turned into plesent Dreams...You know the ones Honda's are powered buy..... ref european advert... google it!!
Herbie1964 is offline   Reply With Quote
Sponsored Links
Tags
17cdti , 2001 , civic , crv , fix , home , honda , limp , maintenance , mode , schedule
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
