Trunk Release Handle Stuck In Locked Position - Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 04-01-2009   #1
jhk1976 is an unknown quantity at this point
Unhappy Trunk Release Handle Stuck In Locked Position
Help!
I have a 2005 Honda Civic LX Special Edition. My trunk release handle has a lock on it, so you can use the master key to lock the trunk release handle, preventing the trunk from being opened from inside the car. Last week I locked the trunk handle, but have been unable to unlock it. I insert the master key and turn it from the locked to the unlocked position, but the handle is still locked somehow. When I turn the key, I don't seem to feel any resistance from inside the locking mechanism, so I have a feeling something's come undone in there.
I'd like to fix this myself if it's something simple. Anybody know how I can go about opening the sucker up to see what's going on and/or how to fix it?
jhk1976 is offline   Reply With Quote
Old 04-01-2009   #2
badhabits's Avatar
badhabits is an unknown quantity at this point
Re: Trunk Release Handle Stuck In Locked Position
ignore everything i say.
you could probably just pry the plastic cover off, and move the lock manually :P
but then if u crack it (and u will) ud have to buy a new cover, but i doubt they could be too expensive :P
badhabits is offline   Reply With Quote
Old 04-01-2009   #3
that lock is a joke lol. yeah just try to pry out the top plastic piece and play with it. spray some lube in the hole too maybe its jammed. i dont even use it cause if you forget its locked and yank the handle, it will prolly snap off.
gearbox is offline   Reply With Quote
Old 04-02-2009   #4
25+ Years Driving Japanese Automobiles
CraigW's Avatar
I have a bulletin for something similar to this on my home pc. I will try to locate and post it.
CraigW is online now   Reply With Quote
Old 04-02-2009   #5
CraigW's Avatar
Cant find the TSB... Forgot I lost some stuff a while back.
I attached the page from the manual.
Old 03-08-2010   #6
spawnaside is an unknown quantity at this point
I also have the same problem! Did anyone find a solution?
Trunk release will not work. The key will turn the lock but the handle never becomes operational...
Are there any good sites for the TSB?
spawnaside is offline   Reply With Quote
Old 03-09-2010   #7
CraigW's Avatar
I had the same thing recently, I used a multi-folded sheet of paper wedged between the lock cylinder and the metal bracket on the rear side. It moved the bottom of the cylinder forward and allowed the 2 mechanism to start meshing again and it has worked fine since.
Once the covers are removed the lock cylinder can be pryed straight up for removal.
Thread Thread Starter Honda Civic Forum Replies Last Post
2006 Honda Civic Si Emergency Trunk Latch Fails! Adam925 Mechanical Problems/Vehicle Issues and Fix-it Forum 6 03-23-2016 08:25 PM
Trunk/Fuel Door Release Cable - A Different Kind Of Question DerbyDad03 Mechanical Problems/Vehicle Issues and Fix-it Forum 3 07-11-2015 04:43 PM
So youve locked your keys in the trunk, and your trunk latch does not work. Now what? geoffm1234 Exterior 3 06-03-2015 08:18 PM
Passenger side power window stuck in up position numbersguy Electrical 1 05-14-2015 09:51 PM
2015 remote trunk release carhag2000 Mechanical Problems/Vehicle Issues and Fix-it Forum 4 04-25-2015 01:33 PM
Tags
2001, 2003, 2004, 2006, civic, honda, keys, lock, locked, master, problem, stuck, trunk, trunk release handle, unlocking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright 2007 CivicForums.com
