Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen > Mechanical Problems/Vehicle Issues and Fix-it Forum
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 03-07-2009   #1 (permalink)
wallydude03's Avatar
Points: 6,021, Level: 50
Points: 6,021, Level: 50 Points: 6,021, Level: 50 Points: 6,021, Level: 50
Level up: 36%, 129 Points needed
Level up: 36% Level up: 36% Level up: 36%
Activity: 6.3%
Activity: 6.3% Activity: 6.3% Activity: 6.3%
wallydude03 will become famous soon enough
Send a message via AIM to wallydude03
DIY: replacing power window motor assembly on my civic coupe
My power window motor assembly broke so i replaced it today. I hope that these pictures will help anybody in the same situation as is was.
Start by removing the handle:
Click the image to open in full size.
unclip the handle wire and power lock button if you have it:
remove this screw by the power window control panel:
disconnect the cable:
remove the 2 screws holding the door panel:
pop off this plastic piece by the mirror:
Now grip the panel from the bottem by the speaker, start popping off the panel:
rip off that white plastic on the door if you want:
Connect the window control panel back up and move the window up until you see the 2 bolts through the two holes on the door:
remove the window motor connector and unclip it from the door:
remove the window:
Remove the 4 bolts that hold the window slider:
Its out!
I hope this helps anybody who has a similar problem
wallydude03 is offline   Reply With Quote
Old 03-30-2009   #2 (permalink)
ph0ng's Avatar
Points: 8,407, Level: 61
Points: 8,407, Level: 61 Points: 8,407, Level: 61 Points: 8,407, Level: 61
Level up: 86%, 43 Points needed
Level up: 86% Level up: 86% Level up: 86%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
ph0ng is an unknown quantity at this point
Send a message via ICQ to ph0ng Send a message via AIM to ph0ng Send a message via Yahoo to ph0ng
Re: DIY: replacing power window motor assembly on my civic coupe
Good post.
I just got finished fixing my passenger side window. The process was exactly as you described, minus one part... My window was stuck in the down position! So removing the mounting bolts for the glass was a pain in the ***.
Once I took the motor unit out, found out everything was working perfectly. Unit ended up getting jammed. Put everything back in and now it actually works better.
Once you have everything out, its a good time to grease the track for a smoother ride.
Thanks!
__________________
-ph0ng
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
Kristian Wilson, Nintendo, Inc, 1989
Typical Car Link
ph0ng is offline   Reply With Quote
Old 03-30-2009   #3 (permalink)
lordhelmet's Avatar
Points: 41,969, Level: 100
Points: 41,969, Level: 100 Points: 41,969, Level: 100 Points: 41,969, Level: 100
Level up: 0%, 0 Points needed
Level up: 0% Level up: 0% Level up: 0%
Activity: 0%
lordhelmet has a reputation beyond repute lordhelmet has a reputation beyond repute lordhelmet has a reputation beyond repute lordhelmet has a reputation beyond repute lordhelmet has a reputation beyond repute lordhelmet has a reputation beyond repute lordhelmet has a reputation beyond repute lordhelmet has a reputation beyond repute lordhelmet has a reputation beyond repute lordhelmet has a reputation beyond repute lordhelmet has a reputation beyond repute
Send a message via AIM to lordhelmet
DAMN! That's a great write-up! I don't know how I missed this post a couple of weeks ago. Have some rep.
__________________
I click on civicDave's links no matter how broken they are!
lordhelmet is offline   Reply With Quote
Old 05-27-2009   #4 (permalink)
Points: 8,265, Level: 61
Points: 8,265, Level: 61 Points: 8,265, Level: 61 Points: 8,265, Level: 61
Level up: 39%, 185 Points needed
Level up: 39% Level up: 39% Level up: 39%
Activity: 0%
lapchern is an unknown quantity at this point
how did you remove the window exactly? my window is currently stuck in the down position. thanks.
lapchern is offline   Reply With Quote
Old 05-27-2009   #5 (permalink)
Activity: 6.3%
^I would try directly applying power to the power window motor connector and see if the window can roll up. The easiest way to remove the window is to lift it up so that you can see the 2 bolts throught the 2 holes in the door
Old 09-08-2009   #6 (permalink)
Points: 1,963, Level: 26
Points: 1,963, Level: 26 Points: 1,963, Level: 26 Points: 1,963, Level: 26
Level up: 63%, 37 Points needed
Level up: 63% Level up: 63% Level up: 63%
Activity: 0%
Atromos is an unknown quantity at this point
Quote:
Pretty easy, you just unscrew it from the slider. If you were looking at it, you'd know what to do I'm pretty sure. Getting the door's plastic bits and whatnot off is probably the biggest chore... all I can say is be careful with the metal tools, they kill plastic like a mo.
Atromos is offline   Reply With Quote
Old 09-15-2009   #7 (permalink)
Points: 1,710, Level: 24
Points: 1,710, Level: 24 Points: 1,710, Level: 24 Points: 1,710, Level: 24
Level up: 10%, 90 Points needed
Level up: 10% Level up: 10% Level up: 10%
Activity: 0.6%
Activity: 0.6% Activity: 0.6% Activity: 0.6%
civic_goober is an unknown quantity at this point
Quote:
This was a great post. My driver side window pwr regulator assy cable snapped and this post saved me big bucks by showing me how to do it myself on my 2001 Civic LX
I saw on other postings where I could get the power window regulator assembly online. I saw places like MajesticHonda.com it's $179.00. Their site has some errors. They had 3 parts listed.
Power window regulator assy 59.00
Power window regulator assy 179.00
Power window regulator 59.00
I called to find out which one was the right part for my car. They told me the obvious...the 179.00 part.
I also checked some other sites that sell "Direct OE Fit" parts. I IM'd the technical support and they told me that it's an aftermarket part from Dorman that will work - price 77.00. Some other aftermarket parts sites sell others like Dorman for as low as 52.00.
I was visiting the Hamilton, NJ area and I called the local Honda dealer. Hamilton Honda. price...$80.07 + tax.
for the whole assembly. So check locally and compare prices.
Out of curiosity, I also called the Lakeshore Honda Dealer in Toronto, ON, Canada. And surprise the part costs $225.00 CAD. What exchange rate are they using?
It's not hard. Except for pulling out those white **** things that hold the door trim in place. If you have one of those forked flat head screw driver tools that removes this trim holder grommet. It's super easy.
civic_goober is offline   Reply With Quote
Old 10-22-2009   #8 (permalink)
Points: 4,103, Level: 40
Points: 4,103, Level: 40 Points: 4,103, Level: 40 Points: 4,103, Level: 40
Level up: 77%, 47 Points needed
Level up: 77% Level up: 77% Level up: 77%
Activity: 0%
jwai is an unknown quantity at this point
Hello i have an 05 civic sedan es .. an Australian model. Here we drive on the right hand side. Therefore i am wondering if a US regulator for the FRONT left would fit MY AU model for front left. Here is what i'm thinking of buying :
http://cgi.ebay.com/ebaymotors/01-02...Q5fAccessories
I called up my local honda spare parts: they are selling them for 600AU.. jesus christ
jwai is offline   Reply With Quote
Old 10-27-2009   #9 (permalink)
Images: 3
silviacivic is an unknown quantity at this point
hey i'm kinda new to the whole forum thing and i didnt know how to search or any thing so i'm just replyin to this and askin for directions on replacing a 6th gen coupe window someone broke into my car and now i'm out a driver side window some ppl say its hard others say i can do it myself but i'm not sure...help?
silviacivic is offline   Reply With Quote
Old 10-27-2009   #10 (permalink)
Images: 3
Old 11-17-2009   #11 (permalink)
Gumdrop's Avatar
Points: 2,518, Level: 30
Points: 2,518, Level: 30 Points: 2,518, Level: 30 Points: 2,518, Level: 30
Level up: 46%, 82 Points needed
Level up: 46% Level up: 46% Level up: 46%
Activity: 0%
Gumdrop is an unknown quantity at this point
for this DIY, do you have to roll the window down while removing the door panel? or should you keep it rolled up?
Gumdrop is offline   Reply With Quote
Old 03-26-2010   #12 (permalink)
mkabatek is an unknown quantity at this point
Smile Re: DIY: replacing power window motor assembly on my civic coupe
Thanks. The part cost 50$ w/ shipping off ebay, and it took me about 1 hour to do! Easy. Thanks again.
mkabatek is offline   Reply With Quote
Old 07-31-2010   #13 (permalink)
Points: 1,920, Level: 26
Points: 1,920, Level: 26 Points: 1,920, Level: 26 Points: 1,920, Level: 26
Level up: 20%, 80 Points needed
Level up: 20% Level up: 20% Level up: 20%
Activity: 3.2%
Activity: 3.2% Activity: 3.2% Activity: 3.2%
jimmyjames1387 is an unknown quantity at this point
I agree with the other posts. This was extremely helpful, it would have taken me MUCH longer to figure this out on my own. The only problem I ran into was in reinstalling the window. The motor is moving the window really well, but after it gets past about halfway down it binds up a little and won't go all the way down. Any tips on how to properly reinstall the window?
jimmyjames1387 is offline   Reply With Quote
Old 07-31-2010   #14 (permalink)
25 Years Japanese Autos
CraigW's Avatar
Points: 21,035, Level: 91
Points: 21,035, Level: 91 Points: 21,035, Level: 91 Points: 21,035, Level: 91
Level up: 37%, 315 Points needed
Level up: 37% Level up: 37% Level up: 37%
Activity: 72.7%
Activity: 72.7% Activity: 72.7% Activity: 72.7%
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
^^^ Make sure your upper and lower tracks/channels are clean and also make sure the rubber inserts are not deformed or out of place.
CraigW is offline   Reply With Quote
Old 07-23-2011   #15 (permalink)
Points: 30, Level: 1
Points: 30, Level: 1 Points: 30, Level: 1 Points: 30, Level: 1
Level up: 60%, 20 Points needed
Level up: 60% Level up: 60% Level up: 60%
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
mbryanr is an unknown quantity at this point
Another great photo tutorial for 2006-2011 Civics...made my job so much easier!
http://www.paulstravelpictures.com/H...ide/index.html
mbryanr is offline   Reply With Quote
Old 04-12-2012   #16 (permalink)
Points: 49, Level: 1
Points: 49, Level: 1 Points: 49, Level: 1 Points: 49, Level: 1
Level up: 98%, 1 Points needed
Level up: 98% Level up: 98% Level up: 98%
Activity: 3.2%
tongsmith is an unknown quantity at this point
hay what do i do if my window is stuck all the way up thanks for your time ppl <3 Honda4life
tongsmith is offline   Reply With Quote
Old 05-02-2012   #17 (permalink)
Points: 190, Level: 3
Points: 190, Level: 3 Points: 190, Level: 3 Points: 190, Level: 3
Level up: 80%, 10 Points needed
Level up: 80% Level up: 80% Level up: 80%
Activity: 1.6%
Activity: 1.6% Activity: 1.6% Activity: 1.6%
kuke554 is an unknown quantity at this point
kuke1018 kuke554
I also would like to know if there are any other changes that would need to be made if the window is stuck in the up position?
kuke554 is offline   Reply With Quote
Old 05-02-2012
CivicForums
Honda Civic
Paid Advertisement
Tags
2001 , 94 , broke , civic , diy , door , honda , motor , power , replace , slider , switch , take apart , window , window removal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Who's had a bad transmission? *UPDATED*
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Your answer may be here! TSB / Honda Complaint Address / Etc...
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
ODB II Codes
DRL Problem
I Got 2 ECU Codes P1298 and P1519
check engine light
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
