Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-09-2008   #1 (permalink)
SalvageRedo
New Member
SalvageRedo's Avatar
SalvageRedo is an unknown quantity at this point
Send a message via AIM to SalvageRedo
Reseting the Maint Required light
I didn't find this on here so thought I would post a helpful tidbit. Recently my Civic threw a couple Codes my way. O2 sensor and IAT sensor. I replaced them and the light center Maint Required light didnt go off. I unhooked the Neg terminal and pulled the #6 ECM fuse for 2 minutes. The Maint Required light was still on. I went to my shop class to see if it was still throwing the same codes or different ones. After running the OBDII scanner... it wasnt throwing [any codes! WTF?!
Apparently if you 1) Turn off the car 2) Push and hold the odometer/tripometer button (the one on the right) 3) Turn the ignition to on (don't start the car) 4) Continue to hold the button for about 10-15 secs, it will reset the light!
If something is still wrong it will light up again, but if for some reason it doesnt want to turn off and there is nothing wrong then this will save you from wondering what's making your baby sick.
SalvageRedo is offline   Reply With Quote
Sponsored Links
Old 12-09-2008   #2 (permalink)
Albertross
Member
Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned Albertross should not be questioned
Re: Reseting the Maint Required light
Maintenance required light will show up every 4k-5k miles, I forget what the interval was. It won't light up "if something is still wrong", that's what your CEL is for. the MRL is there to remind you to do an oil change, lol.
Albertross is offline   Reply With Quote
Old 12-10-2008   #3 (permalink)
SalvageRedo
New Member
I didnt know that. But it was the only thing illuminated when I found the 2 codes P0113 and P0132. Thanks for the info though
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
