| Re: Power Door Lock Problem PLEASE HELP!!! Sounds like the actuator on the lock assembly needs to be replaced, I had the same issue on the passenger side door. It wouldn't work from my remote or the switch inside, I could only lock & unlock the door manually. I replaced the actuator & everything been fine since. |
