Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-20-2008   #1 (permalink)
imprezagtr
New Member
imprezagtr is an unknown quantity at this point
Gas pedal not working well
my gas pedal doesn't go back up as fast as it used to be when i release my foot. i just replaced the flywheel and clutch. is there anythign i need to check? maybe spring or something that usually push the pedal back? thanks. To remove this ad, register today for free or log in if already registered!
imprezagtr is offline   Reply With Quote
Sponsored Links
Old 11-20-2008   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Gas pedal not working well
the cable might need to be lubed.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 11-20-2008   #3 (permalink)
civicsrcool
Super Member
civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned
flywheel/clutch and your gas pedal are nothing related. if you have a civic ex there are 2 spots for the throttle cable to mount on, maybe you mounted it on the wrong one? or maybe your jsut trippin lol. in addition to that maybe you should tighten up your throttle cable.
__________________
here is my pos
civicsrcool is offline   Reply With Quote
Old 12-11-2008   #4 (permalink)
jackscivic
Senior Member
jackscivic's Avatar
jackscivic will become famous soon enough
Send a message via AIM to jackscivic
Try cleaning your throttle plate. It probally has residue from normal driving causing it to stick. Its a common issue for honda throttle bodies.
__________________
If it's to loud, then you're to old!
What is stupider my signature or you for reading it?
jackscivic is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
