Green Light Picture Of A Key Blinking Nonstop
Old 09-16-2008
IrockCivics's Avatar
I have a problem for like for 2days in my dash like next to the gauges a green light shape like a keys been blinking non stop... Before it used to blink like as soon as I turn on my car like for 3seconds but now It just stays blinking the whold time my cars is on and it does not go away, what could it be?
Old 09-17-2008
Re: Green Light Picture Of A Key Blinking Nonstop
its the immobilizer security saying theres a problem with your key.
Old 09-17-2008
is that bad?
Old 09-17-2008
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
No. You don't need the key anyway.
Of course it's bad, are you serious? Did you have an aftermarket alarm installed with immobilizer bypass? My Compustar confuses my car sometimes and makes the key blink but not very often. Otherwise try a different key and see if maybe it's just the chip.
Old 09-17-2008
does the car start? im guessing no. if it does, the immobilizer is effed
Old 09-17-2008
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
sounds like it starts and drives
Old 09-17-2008
well, the car can be on without the engine running
Old 09-18-2008
Yes the car is on when is blinking and when I'm still driving the light is still blinking. But it havent done it today.
Old 07-26-2009
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Did you get this resolved? I have noticed the past couple of weeks that my immobilizer light blinks while driving. I'll just turn off and pop the clutch and it goes away. Then a couple days later same thing. I have a dying battery, any correlation?
Old 07-26-2009
ive had the light come on when the battery cable was loose.
Old 07-26-2009
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
I say either it's all the problem mentioned above, or maybe you submerged your key in water enough times, or let it sit next to a magnet or something.
Old 08-07-2009
bobsagator's Avatar
Finally replaced the battery a week ago and it hasn't happened since. So it may have been a loose battery cable.
Old 01-17-2011
nuxil's Avatar
nuxil is an unknown quantity at this point
sounds interesting, I just had that issue today when I start my car with the key.
When I start it with compustar and then put the key in ignition, only then it's just fine...
(Yea i know it's a old topic, but didn't want to create a new one)
what can be the problem, compustar or battery lol
Old 01-19-2011
bobsagator's Avatar
Hasn't happened again since changing the battery back in 2009. I'm gonna say it has to do with the battery or battery cables.
PinkCupcakes
Electronics
07-18-2019 12:50 PM
davidarenberg
05-16-2015 08:45 AM
Linda0818
04-23-2015 11:30 AM
blackbullet
12-01-2001 03:44 PM
supercivic01
South
11-30-2001 11:27 AM
Quick Reply: Green Light Picture Of A Key Blinking Nonstop
