Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-02-2008   #1 (permalink)
TOOLOWCIVIC
Ultimate Member
2001 civic stalling, backfiring
So about a month or so ago I was driving home from work when my car just started to backfire. Atleast I thought it was backfiring. So I pulled over. My cars exhaust sounded very loud and crackling. I would give it gas but the car was just barely moving. I turned it off. After like maybe 10 minutes I turned it on and the car sounded fine. I drove off with no problems. The engine light was not on. I had someone check it and they saw no problems. Today it did the same thing. I turned it off and right back on it worked fine. Anyone have any clue as to what this could be? My car is not overheating. Not sure what it is. Only mod I have is an AEM intake. To remove this ad, register today for free or log in if already registered!
TOOLOWCIVIC is offline   Reply With Quote
Sponsored Links
Old 09-03-2008   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: 2001 civic stalling, backfiring
cat is starting to clog? idk hard to say. might be some small exhaust leak
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 09-05-2008   #3 (permalink)
TOOLOWCIVIC
Ultimate Member
I took it to see why the check engine light was on and this is what was shown P1361 and P0113. Anyone else have this and how did u fix it?
Old 06-28-2009   #4 (permalink)
MidnightCivic
MidnightCivic's Avatar
MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light MidnightCivic is a glorious beacon of light
Send a message via Yahoo to MidnightCivic
any updates? i got the same damn code P1361
__________________
Current Mods
• DIY BOH • Progress Rear Sway
• Yellow Fogs • Altezza Grill
• 16 red/black te37 replicas • ep3 side markers
• Hayame Cat Back • K&N fipk intake
• D2's • 04 Smoked Taillights
• Cf Hood • Neuspeed Strut Bar
• Aero Sides • Oem Rear Lip
• Type B Front Lip • D3S Retro Headlights
Future Mods
• CF Trunk
MidnightCivic is offline   Reply With Quote
Old 06-28-2009   #5 (permalink)
tbohar
Senior Member
tbohar's Avatar
tbohar is on a distinguished road
P1361 TDC Sensor Intermittent Interruption
P0113 Intake Air Temperature Circuit High Input
Check your TDC sensor, upon further reading online there is a service bulletin on this issue. Honda appareantly says you need a cylinder head replacement ( ?? ) for this. The TDC sensor is located on or around the timing belt housing. I also found that it costs about the same as replacing a timing belt so you may as well do that at the same time? (Oh boy)
tbohar is offline   Reply With Quote
Tags
2000 , 2001 , backfires , bulletin , cel , check , civic , engine , honda , intake , intermittent , light , p1361 , stalling , tdc
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
